Hi all
My rear shock has gone. Its a 2012 r1200r esa version, and I cant seem to source a replacement. Does anyone know if the shock is unique to the r1200r, or the same as would fit other models?
Thanks if anyone can help.
Dan
Rear shock esa
- Honorary Lifer
Re: Rear shock esa
It probably is unique - since the other models weigh more. The spring at least is probably different (shock may be the same.) EPM in Manalapan NJ is capable of rebuilding the ESA shocks.. http://epmperf.com/motorcycle-shock-rebuild-service/
