So I'm on my way to work today and suddenly my R turn signal stops working. L is fine.
Also, whenever I hit the front or rear brake, the battery light comes on, and the RPM needle drops to zero!
When I release the brake lever, the batt light goes off and the RPM needle comes back up.
Bike starts and runs totally fine otherwise.
I have a feeling the fuel tank is coming off soon, but any initial thoughts?
Thanks.
Hope this post survives the bot-sweep.
2002 R w/ 40K miles, I clipped the front cable ties when I got the bike with 13,700 miles on it in 2013. Battery is 2 yrs old.
Electrical weirdness!
2002 R1150R
"Better is the enemy of good enough"
- my brother-in-law's brother
- riceburner
Re: Electrical weirdness!
deffo sounds like a broken wire somewhere!
Even if you did clip the cable ties around the headstock wiring, it'd be the first area I'd be checking.
thanks. was thinking that as well. I'll see if the same thing happens with the bars turned all the way to the R and L.
If that is the case, do you just fine the break and re-solder it and shrink wrap that damaged segment?
2002 R1150R
- riceburner
sstein wrote:thanks. was thinking that as well. I'll see if the same thing happens with the bars turned all the way to the R and L.
When I had the issue (at something like 85000 miles, after cutting the cable-ties at about 2000 miles), I just replaced the damaged loom - it was far, far easier.
Not ABS.
You replaced the whole loom - like all the electrical wires on the whole bike? That sounds a lot more complicated to me, but then again I have no experience with this...
2002 R1150R
Don't you have to like remove the engine and the hand controls and all of that to replace the whole loom?
2002 R1150R
Does the brake activation produce symptoms when bike is not in motion?sstein wrote:Not ABS.
Can you measure system voltage during brake activation?
- riceburner
Sorry - not the WHOLE loom - just the ignition switch spur (which was the worn out part).sstein wrote:Not ABS.
My mistake, should have been clearer.
thanks for the responses.
Sweatmark - I'll check to see what happens when not in motion. To check the system voltage, I can use the (+) and (-) battery leads, correct?
I'll try to get to that this weekend.
Riceburner - I didn't know that individual sections of the loom can be replaced. May have to do that.
I've read on this forum how daunting it can be to find the problem. Will need plenty of help! (or a professional)
2002 R1150R
Or you could measure at accessory socket using spare plug and wires, saving you from tank removal* right away. Your front/rear brake switch activation experiment could help narrow troubleshooting focus. I looked over my R1150R wiring schemata Monday after reading your post.sstein wrote:thanks for the responses.
* As posted here before, I actually enjoy removing & replacing the R1150R fuel tank!
Re: Electrical weirdness! -- HELP
So here is some follow up info:
Start bike in nuetral --> no neutral light, no battery light, no oil light, no needle movement on tach
rev the RPMs --> battery light comes on and tach starts, netral light on but weak
activate hand or foot brake --> battery light glows bright, tach needle goes to zero, no brake light (or hyperlites)
release brake --> battery light goes off, tach needle goes back up but seems to to run lower than expected
I have NO flashers or flasher lights on instrument panel
hazards work fine
bike starts and runs fine
2002 R1150R non ABS 40K miles, 2 yr old battery
I checked the battery voltage through my trickler wire - 12+ volts. started the bike and bumps to 13+ volts. pulled in the hand brake lever- no change in voltage.
pulled the tank and did not see any obvious bare wires.
Any suggestions on how to proceed would be great.
Seems from the wiring diagram (Clymer) that the neutral light, brake lights, flashers, battery indicator may all be in circuit together?
Steven
hazards work fine
Steven
2002 R1150R
So, after pulling the tank and staring hopelessly at all those wires, I decided to check the fuses and found #1 blown. Replaced it and everything works again. Could it be that simple?
2002 R1150R
Fuse #1 is for Instruments. They must have been backfed through the brakelight circuit after the fuse blew. Do you know why that fuse blew?
Rich
ADIOS!
ADIOS!
No I dodon't.
2002 R1150R
- Mr.Frequent
Been following this . .the culprit - that fuse- was unexpected. I would never have imagined that. Good,methodical followup on finding the problem! Well done,sstein.
Guessing it's not that simple.sstein wrote:So, after pulling the tank and staring hopelessly at all those wires, I decided to check the fuses and found #1 blown. Replaced it and everything works again. Could it be that simple?
Why did Fuse 1 blow? It's another symptom of the underlying problem.
Always check the fuses as 1st step in electrical troubleshooting (reminding myself).
Fuse 1 for non-ABS R1150R is also brake switches/lamp.Sunbeemer wrote:Fuse #1 is for Instruments. They must have been backfed through the brakelight circuit after the fuse blew. Do you know why that fuse blew?
- towerworker
Sure glad you found it. Was gonna suggest you check the antifreeze.....
'05 RT
'04 R
'03 R
CB750
KZ750
HD 350 Sprint
'05 RT
'04 R
'03 R
CB750
KZ750
HD 350 Sprint
