Is this the type of clamp to use when replacing the leaky, recalled, OEM crimp clamps?
http://us.st11.yimg.com/store1.yimg.com ... 71_8664959
How many do I need?
What size, 5/16?
Can't ride for the snow so I have to spend quality time with her SOMEHOW!!
DSKYZD
Fuel line clamp replacement, is this the one, and how many?
JOURNEY JUNKIE #187
Thanks Thad! This particular site has 3 sizes. The smallest is 1/4 inch, that small?
John, this is the site:
http://www.autobarn.net/iddifuincl.html
It was the "I'm Feeling Lucky" link when I Googled "Fuel Injection Clamps".
I was going to try the local Autozone/Napa/Advance Auto places but wanted to make sure I knew what I looking for.
DSKYZD
DSKYZD
JOURNEY JUNKIE #187
clamps
13mm or 14 mm will work, and you can get them at most autoparts stores. Down here we have Autozone auto part stores, and they all have them. You'll need some end cutters to get the OEM clamps off.
http://www.amazon.com/gp/product/B0003J ... e&n=228013
[/img]
[/img]
The clamps I used were as follows:
12-15mm OD - for use with 8mm ID fuel injection lines.
The nomenclature on the package says: "Smooth interior clamps designed for 12mm OD tubing, designated for fuel injection."
I got mine at Auto Zone - but any auto parts store would have them - just take your calipers with you and make sure they are 12-15mm OD - there is a larger size - but standard "fuel injector" tube clamps are what you want.
Bill Haycock - Member #78
Huntsville, AL
Huntsville, AL
OOPS! Started to take off for a ride today and smelled the smell that strikes fear in the heart of mankind. GASOLINE!
It was drip-drip-dripping! Ran back home quickly and took a look. Yeppers! It's that darn clamp problem. I should have just gone ahead and replaced those when I had the tank off last time. I am suspicious that they may have dripped some before unnoticed. What with the stained tranny cover and all. Oh well.
It's off to Auto Zone now. By the time I got home there appeared to be only one dripping. The lowest outside, below the QDs. But the others are not long for this world either.
So much for my nice riding day.
Here's a question, and feel free to laugh at me if you want to, but what do you do about the gas in the tank when replacing these clamps? Can it be done without disconnecting the lines and letting gas get everywhere?
Then, if draining the gas is the proper first step, how exactly is that accomplished? Just unhook a fuel line and let it drain into a container? Seems obvious, but what's the best way?
DSKYZD
DSKYZD
JOURNEY JUNKIE #187
I've just returned from AutoZone, Advance Auto Parts, and NAPA
Nobody had these animals except Advance and they didn't have the 5/16" ID size in stock. The ones in that AutoBarn ad are the same ones at Advance. Made by a company called "Ideal". Thus the part number IDE52F series numbers. Bills metric sizes for ID is 8mm and the Advance guys said thats 5/16" equivalent. Number IDE52F15. And they were out!
Now I gotta locate another Advance parts store. I did get me a pair of those little nipper pliers and have taken off two of the old ones already. I just need to find some new ones now.
Bill, if you're there. What was the brand of the ones you bought with the metric sizes on the package?
That's OD Bobby. The ID should be 8mm or 5/16". I noticed pretty quickly (just finished doing the bottom 4 BTW) that the line on the end of the QD is a larger diameter than the fuel line. The hose would not pull off with my fingers. I just left it and moved the other clamp up to that position from the end. Plus it wouldn't clamp down near all the way. So, to to it exactly right, the clamp to the ends of the QD are probably more like 3/8".
What I have been using with no trouble is the following:
IDEAL 52F15v
On the back it says "Fits 5/16" I.D. hose"
5/16" is also 8mm
They work fine on mine and believe them to be what you need.
I have four here - I can send them to you if you need them.
IDEAL 52F15v
5/16" is also 8mm
Boxer wrote:Bills metric sizes for ID is 8mm and the Advance guys said thats 5/16" equivalent. Number IDE52F15. And they were out!
Huntsville, AL
Huntsville, AL
Thanks Bill, but I found some finally at an Advance Auto Parts place up by my school.I have four here - I can send them to you if you need them.
I replaced the bottom four already and will just wait until I have the tank off again to do the others. It was the very bottom one that was leaking this morning. I just missed my good sunny riding day.
