I assume a lot of you here are using this...
I am planning some longer rides on my bike, and thus I ordered a touring windsheild, and now I'm considering the cruise control.
So my questions are - does it actually work? And, do we want the standard or heavy end weights? I would assume the heavier ones would be a better bet.
Also, where should I order this from? Any place we know that has these in stock? I think I'll do the black ones as opposed to silver.
Thanks,
- Anthony
Throttlemeister Cruise Control
Re: Throttlemeister Cruise Control
I just installed one a month ago, it does work, and it is easy to use. The only issue I have with it is, when the heated grips are used on the high setting, the grips expand just enough to tighten the grip tension. Friction goes up, and the throttle lock will not relax and let go of the grip without more muscle applied to make a change in throttle position. The throttle is still able to be adjusted, but the "off" setting can not be achieved due to the increased friction on the grip. It is a minor annoyance that shouldn't make the bike less safe to ride, it just takes a little more effort to change throttle position, if you take a spill though, your throttle will be stuck until you pick yourself up and turn the engine off. I got mine at Santa Cruz BMW.
Don
Don
The Throttlemeister works just fine and looks nice. It doesn't work as well as the Flip a lever type that I have on the R65 but that type will not work on the Roadster. I believe the 'standard' Throttlemeister is already heavier than the stock bar end weights so that is the way I went. It is possible to adjust the Throttlemeister to work with the heated grips but will require you to be patient and fussy. Adjust it so it barely disengages when the grip heaters are on high. I think I took one of the shims and kept filing it down a bit at a time until I got the adjustment I wanted. I ordered mine directly from the Throttlemeister folks. http://www.throttlemeister.com/
I only use it when I need to rest my hand a bit on longer trips and NEVER in busy traffic or on crooked roads.
Neal
Neal
'81 R65
'04 R1150R
'04 R1150R
I like the Kaoko throttle control. It is a well made product, and it works. But, I have not tried any alternatives.
http://adventurersworkshop.com/Merchant ... OKO_CCF100
My "R" came with the Throttlemeister - never noticed any effect from the grip heaters, so it must have been well adjusted previously. Anyway, it does indeed work well. I found that I relax BOTH hands when I engage it. You will notice any rises or drops in terrain - speed decreases or increases - so I keep the friction set so I can make minor adjustments if I want. Most of all, it helps reduct pilot workload. On long rides, I can enjoy the scenery a bit more, and enjoy the ride more.
Member #1058
I had a Throttlemeister on my Triumph, but lust for a Kaoko to put on my R.
The problem with the Throttlemeister is the smooth finish makes it difficult to engage/disengage. Looks nice. The Kaoko has those gear cog thingys so it should be (this is only theoretical) much easier to adjust.
I use a Bob's Wrist Rest http://store.bobsbmw.com/index.asp?Page ... =GO&Page=1simply because one of the folks in my local BMW group had taken it off his bike and wanted only $35 for it. It is very similar to the TM unit and has the same drawback, namely that it is somewhat tricky to actually lock/unlock the tension ring. I have a Crampbuster as well which makes adjusting things a lot easier. The Kaoko cog-type ring looks like a better design but I'd bet that a crampbuster would help there as well. If you go with the TM, these guys seem to have the best price: http://www.casporttouring.com/store/mer ... tlemeister
As others have reported, a throttle lock is only moderately useful since it's not a true cruise control and will require more or less constant readjustment. Still, on longer rides, they provide welcome relief and IMHO, are a worthwhile accessory.
Charlie
Charlie
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
Life member 365
The problem with the Wrist Rest is they turn the wrong way. The Throttlemeister locks when it turns the same direction as opening the throttle. Duh.
And I agree on the Crambuster/Throttle Rocker, simple and effective. But on a long ride a throttle lock is an excellent accessory to have.
I have the Kaoko and like it very much. It is easy to set b/c the cog wheel is reverse threaded so counter-clockwise (accelerate) tightens it if you over-grip the grip+cog, and contrarywise, CW loosens it. That's probably the way the 'meister works too, right? I've also found I can set it using my pinky, so I don't have to be accelerating to set it either. On the original installation it was too tight, so I installed a thin washer inside the bar-end to hold it a little further out off the grip. Worked like a charm. When running heated grips it "tightens up" a bit, but its not at all difficult to re-adjust.
I've found I really only use it on long, straight, flat runs where constant speed is easy to attain. If you're going up and down hills or where you have to modulate your speed much you have to constantly work against the added friction---you end up with more wrist fatigue than without it in those situations.
-d.
-d.
-duckdave
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
I've got a Throttlemeister fitted. It looks great in polished stainless steel, but... it's very difficult - imo dangerously so - to engage/disengage whilst riding - a third hand would be useful!. The inabilty to enage/disengage easily whilst riding renders the device almost useless, imo. Holding the throttle open and trying to tighten/loosten the thing at the same time is practically impossible and, believe me, I've tried! Consequently, I never use it for its intended purpose. On previous bikes I used an alternative system - forget the make - with a flip lever, which was much more effective as a throttle lock, easy to adjust, and a pleasure to use.
For me, the whole point of these mechanical 'cruise controls' is to be able to engage/disengage them easily - and safely - when riding conditions allow, mainly to enable one to flex one's throttle hand, especially during long motorway stretches. I cannot, in all honesty, recommend the Throttlemeister.
...just my 2 cents
...just my 2 cents
Mike in Hamburg
2004 black R1150R... and a 1930 Thürmer grand piano - heaven!
I use a large rubber o-ring partially installed in the gap for enough friction for throttle control. Works fine and costs about a quarter!
I use GS handguards in the winter and take them off in the spring. That would require two different sets of throttle controls. Too much $$ and trouble. My o-ring is universal fit!
Vann - Lifer No. 295
The Kaoko works with and without the hand guards. You can engage it and disengage it with your pinky.wncbmw wrote:I use a large rubber o-ring partially installed in the gap for enough friction for throttle control. Works fine and costs about a quarter!
I tried something like an O ring (actually it was a girl's pony tail holder) but it is a little more fiddly to use. Of course, it is much cheaper.
I agree with both Rdsmith3 and Duckdave on the Kaokos. The knurled ring makes adjustments easy with the pinky while riding. It's the main reason I choose it over the Throttlemeister. IMO the Throttlemeister looks better...more like the original bar ends but I'd rather have function over form with something as important as a throttle lock.
I believe you but I still bet it costs more than a quarter! Heck, I even carry spares in the tank bag!The Kaoko works with and without the hand guards. You can engage it and disengage it with your pinky.
This cruise control is from Wunderlich, and i enjoy them verry much. these are make from aluminium and do corrode a little bit
Now i can wave to fellow riders with both hands
one concern to me is what will happen incase of an accident? Throttle half open, it will run for miles?
2001 r1150r fast blue, sold
2001 r850rtp polizia municipale Milano
2005 r1150r dark silver
Careful with that waving!Now i can wave to fellow riders with both hands
http://r1150r.org/board/viewtopic.php?f=2&t=13617
Further to my earlier post in this thread... how does one turn throttle locks like the Throttlemeister - SAFELY! - whilst, at the same time, holding the throttle itself steady? My experience with the Throttlemeister is that it's extremely awkward and hazardous to do so.
Mike in Hamburg
Scooch your hand out a little. Grip the Throttlemeister and throttle simultaneously and twist `er open. At least that's how I always used mine. And that's why the Wrist Rest thing struck me as a poor alternative. The better units are LH thread.cruiser wrote:Further to my earlier post in this thread... how does one turn throttle locks like the Throttlemeister - SAFELY!
Other riders have expressed a fear it would lock the throttle- but mine never gripped it that tight.
In fact, I used it even on hilly terrain because you can still move the throttle. It just takes the strain off your right hand because it requires MUCH less grip.
I usually pull in the clutch, tighten the Throttlemeister, then let out the clutch as I advance the throttle. I can also hold the throttle steady while I tighten the 'meister with my little finger. Either way is fine. Having the heated grips on changes the setting, but it still works.cruiser wrote:... how does one turn throttle locks like the Throttlemeister - SAFELY! - whilst, at the same time, holding the throttle itself steady? My experience with the Throttlemeister is that it's extremely awkward and hazardous to do so.
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
Ogden, Utah
2002 R1150RT
2004 R 1150GS
Not actually. I bought a Throttlemeister set on eBay that wasn't intended for use with the GS handguards. I managed to adapt them as I explained in this thread: http://www.r1150r.org/board/viewtopic.p ... 05#p119805wncbmw wrote:I use GS handguards in the winter and take them off in the spring. That would require two different sets of throttle controls. Too much $$ and trouble. My o-ring is universal fit!
I can use it with or without the guards. I also use an "O" ring in the red groove to make it easier to apply it one-handed.
Rick
2003 R1150R: Silver
Lifetime Member #585
2003 R1150R: Silver
