R1200r gas tank removal
bikelee
Post by bikelee »
:?: How do I remove the gas tank on my 2007 R1200r ? Thanks, Lee
mogu83
Re: R1200r gas tank removal
Post by mogu83 »
I was going to take mine off but I worked around it. It would be interesting to know what was involved to remove it. Over 60 hits and no replies.
Maybe you should have started an oil thread. :roll:
BigEasy
Post by BigEasy »
Not hard, it's late now, long day and a couple of dingle (evidently the board doesn't like some words beginining with C and ending in tail but Ive been drinking rum and coke)sooo I can't remember exactly. So search my user name or Ohlin's install and either I or someone else have a post re: removal. Not hard at all, best of luck
Currently:
07 R1200R
07 XB12STT
10 FLHTP
12 Wee Strom ADV
celticus
Donating Member #: 548
Post by celticus »
After removing the seat I just walked around the bike taking out what ever fasteners it seemed necessary to remove the tank. It should come to you.
What is happening to my skin?
Air can hurt you too
famousperson
Sextuple Lifer
Donating Member #: 599
Post by famousperson »
From what I can remember, you start by taking off the plastic trim pieces. on either side. There are two per side. Then there's the fuel line and the connection to the fuel pump. It's pretty easy.
'07 R1200R
Life Member #599
NAUI Inst. #1434 (since 1969)
bikelee
Post by bikelee »
:) Thanks ! I'll try tomorrow. Lee
ka5ysy
Triple Lifer
Post by ka5ysy »
Remove the plastic trim pieces and the one behind the steering head attached to the tank. There is a bolt on the left side that retains the tank which you will see on removing the trim pieces. Slide it (the tank) back carefully and detach the quick connects. Easy!. It also helps to have a tank not full of gas !! Be careful to not lose any of the gazillion screws that hold everything together .
MSF #127350 NAUI #36288
2011 RT
Post by deilenberger »
ka5ysy wrote:Remove the plastic trim pieces and the one behind the steering head attached to the tank. There is a bolt on the left side that retains the tank which you will see on removing the trim pieces. Slide it (the tank) back carefully and detach the quick connects. Easy!. It also helps to have a tank not full of gas !! Be careful to not lose any of the gazillion screws that hold everything together .
Besides the two throttle body covers (2 screws each) - you have to remove the front mounting screws for the side plastic panels that run down under the seat. I recall 2 screws on each. Then after removing the bolt on the left side (T40 from memory..) you can lift the tank a bit, disconnect the wiring, the vent hoses (I'd suggest marking where they connected so you don't confuse them) and the two quick disconnects for the fuel lines.
I'd also suggest having replacement O rings for the quick disconnects. They like to nick on removal and leak on reassembly. They are standard O-ring size 011 - get Viton ones, it's resistant to gasoline. A tiny dab of motor oil on them will make it slide together much more easily (depress the tab on the female one - when the male one is fully home - release the tab.)
All this is from memory - I'm about 400 miles from my bike at the moment.. but should see it tomorrow.
PS - first snow today in the Finger Lakes region of NY state.. I hate snow.
Ferenc
Post by Ferenc »
Had to remove the gas tank recently. I took pictures about the process and added some description. Check the link, hope it helps.
http://lillin.hu/kepek/042_gastank/index.html
"the journey is the aim"
www.lillin.hu
famousperson
Sextuple Lifer
Wow, what a great post! I've been avoiding removing my tank for some time now because, although the steps in the manual are clear, what is where is not. Thank you very much for the clear pictures and explanation. There ought to be a sticky for pictorials like this.
Peter
'07 R1200R
Life Member #599
JohnM
Donating Member #: 852
Post by JohnM »
Ferenc:
Excellent job!! =D>
Ferenc
Post by Ferenc »
famousperson, JohnM, thank you!
www.lillin.hu
tonyd48
Post by tonyd48 »
This link in no longer active. Anyone have pics they can send or a new active link for gas tank removal?
Thanks;
vroomr
Post by vroomr »
Does the tank have to come off to replace the air cleaner? I ask because I attached a second horn to the hole in the right front of the tank and the bike's going in for service. If the tank has to come off I'll remove the second horn temporarily. Don't want the tech to accidentally yank those wires.
Richard
mogu83
Post by mogu83 »
Tank doesn't have to come off
2011 Sportster
vroomr
Post by vroomr »
Thanks.
I just remembered the outstanding fuel system recall; does anyone know if the tank comes off for that?
Richard
dbrick
Donating Member #: 902
Post by dbrick »
vroomr wrote:I just remembered the outstanding fuel system recall; does anyone know if the tank comes off for that?
The tank has to come off for the recall. The tank has to be off the bike to inspect the fuel pump flange, and to add the reinforcing ring or replace the pump assembly.
David Brick
Santa Cruz CA
