Temps are dropping--time to check your antifreeze!
- towerworker
Here in Va we've had some mid-40's morning temps-won't be long before it is down to freezing.
Time to check the antifreeze in your R's dual radiators!!
A properly maintained system will show on the antifreeze tester protection down around -10 degrees or so.
I run a good quality 50/50 mix in mine and it has always tested to at least -20.
Wayne
03 r
Wayne
03 r
DJ Downunder
- Honorary Lifer
So they're radiators....I wondered what they were..Time to check the antifreeze in your R's dual radiators!!
Anyone noticed the duel radiators on the new Suzuki B-King.. http://users.skynet.be/hayabusa/images/bking2.jpg
It was falling in love with the concept B-King that made me love the 50R when I first saw it.
Anyway..Those twin radiators on the B-King are not radiators..not even oil coolers..not even air vents..they do nothing..except make it look like our 50R.
boxermania
- Quadruple Lifer
- geothepencil
Spookymonster
Beemeridian
- towerworker
Ok guys----there seems to be a bit of confusion on the methodology of properly checking your r's antifreeze. I will attempt to vanquish all the seemingly smoke and mirrors.
But first to answer some burning questions:
DJ---yes they are radiators, but not just simple radiators----they are also hand warmers!
MikeCam----hanging with the wrong crowd? That kinda self incriminating isn't it? Who did I think I was going to have to push to get him out of my way on saturday?
Boxermania--yep--I do like the Dew!
Buckster---if you look on page 472 of your owner's manual (in the fine print) you will see that the schematic of the cooling system shows the coolant lines running a complete loop thru the handlebars--I have it on good authority that there is a side benefit in that arrangement---the coolant also absorbs engine vibration above 4K. Easier on the hands plus keeping the pinkies warm! Bottom line is -- Once you've checked the antifreeze level in the engine----the grips are good too!
R4R&R---Sorry just bought some for $15 a gal. If you're interested I'll send you the link.
Geothepencil---is that metric wrench available in left and right handed?
Dr Chew----yes I did although I used a metric timer---does that make a difference?
JCsman-- 3.7463 psi. (except on Sundays--increase by 1psi)
Spookymonster--- Yes I am
Beemeridian----sorry----you're out of luck.
Now I forgot what I was going to say.
Towerworker
Towerworker
DJ Downunder
- Honorary Lifer
- iowabeakster
- Quadruple Lifer
- towerworker
Hmm...
Personally I prefer the anti-freeze solutions manufactured in Scotland. A nightly wee dram of Glenfarclas, Aberlour, or Glenmorangie (or Lagavulin on those REALLY cold evenings!) seems to keep me from freezing up...or worrying about the R tucked away in a nice warm garage!
Just a thought, not much of one, but still, a thought....BJ
- towerworker
Hmm...
That is some really good antifreeze!!
Problem I have with that stuff is when I use it I have a heck of a time getting the wibblin pin on the wobblin gear!
TW
TW
"That is some really good antifreeze!!
TW"
Yup, that's why I don't imbibe whilst ridin'. Oh and one more thought. If the Scottish anti-freeze isn't available, one can make do with the domestic variety...say Wild Turkey Straight Rye.
BJ
TW"
BJ
