Pushed it for 2 miles... Home
zooomart
Post by zooomart »
I wintered my 04 50R(14700 miles) at a friends poll barn with the battery tender plugged in. Half a tank on gas :oops: with some fuel stabilizer in it. I started it with out fuss, it idled for 60 seconds and rode smooth for a couple miles <4k RPM. Stalled at the next light with low power at 3k. Got to gas station and filled up. Ran rough and stalled repeatedly for another mile, then quit. It would start and stay running, rough, with fast idle on but would not rev or allow launching. Seemed to smoke alot when starting
Any ideas of what to check? [-o< Bad coil. Ran well last fall. 3500 miles on last full tuneup. :?
Thanks for any suggestions
2004 Silver R1150R
Sunbeemer
Donating Member #: 593
Re: Pushed it for 2 miles... Home
Post by Sunbeemer »
Water in gas would be my guess. Dump the tank and refill with fresh. Don't know if Dry-Gas is recommended for these bikes, but if you find it's ok, that might work.
Boxer
Donating Member #: 2
Post by Boxer »
ditto on the bad gas guess.
zooomart
Post by zooomart »
Thanks I hope it is that simple. I would of thought the gas stabilizer would of taken care of that. I will follow up when I pull the plugs.
2004 Silver R1150R
awagnon
Post by awagnon »
zooomart wrote:Thanks I hope it is that simple. I would of thought the gas stabilizer would of taken care of that. I will follow up when I pull the plugs.
I don't believe ordinary fuel stabilizer will prevent water contamination, which is likely the cause. Some use "Sea Foam" or other alcohol based additives to suck up the water.
There are still a number of things that could be wrong besides bad gas. Check to make sure the fuel pump is pressurizing when you turn on the key. Pull a plug and check for spark and pull a fuel injector and check for fuel spray. Go from there after you've ruled out bad gas. ( In the bike, not you. )
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
"I wintered my 04 50R(14700 miles) at a friends poll barn with the battery tender plugged in."
Any horses in that barn? I hear they're bad about peeing in BMW gas tanks.
Donating Member #: 312
Post by boxermania »
WATER....crank it up and keep it running with the hand idle....she will buck, shake and the exhaust will smell awfull but she will begin to clear up. Once it can hold some rpm get on and ride
