Why do I sometimes get a puff of smoke at startup?
PA Rider
Post by PA Rider »
It seems like every fifth or sixth I start my beakster I get fairly good sized puff of smoke out the pipe. It may be happening more frequently lately. What could be causing this and is it anything to worry about?
Thanks for any help with this.
2003 R1150R
Oilhead
Re: Why do I sometimes get a puff of smoke at startup?
Post by Oilhead »
Do you keep the bike on the centerstand or the sidestand? If you keep the bike on the side stand, the oil will seep into the left cylinder head and will burn at startup. It only does that once in a while for me. Of course no smoke ever on startup if kept on the centerstand. Just another of those idiosyncracies of our engine. :lol:
2002 BMW R1150R
2004 Honda CBR600RR
2006 Kawasaki KLX250S
2008 Ducati Hypermotard
1996 Ducati 900SS
mnnden
Post by mnnden »
I'm no mechanic, but sometimes when I leave it set on the side stand for any length of time it will "Puff" out a cloud, not all the time but most times, Den
We all gave some,
Some gave all.
Anonymous
Oilhead
Post by Oilhead »
mnnden wrote:I'm no mechanic, but sometimes when I leave it set on the side stand for any length of time it will "Puff" out a cloud, not all the time but most times, Den
Yes that's right. It is the left cylinder head that the oil is seeping into and getting burnt at startup. The early K100 Brickheads were notorious for that. It would actually smoke for a few blocks. That is why everyone that had an early K100 always parked on the centerstand. They fixed it on the later K100 and K75....as a matter of fact, my '95 K75A/3 never had that problem. It actually took a few years for BMW to even address it and I remember one of the mags severely criticized them and even took a shot by saying "if this was Honda, the problem would have been taken care of in the sophomore model year.....actually if this was Honda, they would have designed the brick with the cylinder head on the right side instead of the left". :lol:
2002 BMW R1150R
2004 Honda CBR600RR
1996 Ducati 900SS
Donating Member #: 312
Post by boxermania »
+1 to the above responses, however, it is much more prevalent if the oil level is kept above the middle of the sight glass.
I read this somewhere on this board some years ago. Recommended shutting down engine prior to leaning it over on the side stand. For me maybe two to three seconds will elapse before it's on the side stand. Mine seldom if ever smokes now.
Beemeridian
Donating Member #: 477
Post by Beemeridian »
11
2015 Honda PCX150
PA Rider
Post by PA Rider »
Beemeridian wrote:Have you drained the airbox lately? If it gets filled with enough oil it will do exactly what you are describing.
I just had my beakster in for its 24k service. Would they normally drain the airbox as part of this service? They did install a new air filter. And okay...I don't even know what an airbox is.
Those that provided their input above...thanks for the center stand tip. I'll use the center stand more often now.
PA Rider
2003 R1150R
Buckster
Donating Member #: 543
Post by Buckster »
Your airbox is under the tank where the air filter is at. If they changed your filter at your last service, I'm sure they would have cleaned before installing a new filter. I have not had oil collect in my airbox except for maybe a little residue.
Buckster '03R
#543
Beemeridian
11
2015 Honda PCX150
Boxer
Donating Member #: 2
Post by Boxer »
Allow it to drain for an hour or so.
An hour or so?
I would go to sleep laying there that long. ;)
Beemeridian
11
2015 Honda PCX150
Rog(UK) - Yorkshire Dales
You two remind me of Jack Lemon and Walter Mathau in 'The Odd Couple' or was it 'Grumpy Old Men'? - in a nice way, of course! :)
Rog
2004 R1150R Rockster
1978 Moto Guzzi V1000 Convert
Beemeridian
11
2015 Honda PCX150
