SERVICE indicator on battery disconnect
crazyhorse
does the 'service' word on the instrument cluster always come on after you have disconnected and reconnected the battery?
i installed my warm n' safe heat-troller direct to the battery today and in doing so disconnected the battery for a few moments and now the word 'service' is showing up.
i know i can't get rid of it myself, unless anyone near pasadena, ca has a gs-911. i just wanted confirmation that it always shows up if you disconnect the battery. seems odd.
wes
wes
The Stuck Canuck
In Garage:
08 R1200R
08 WR250R
In Garage:
08 R1200R
08 WR250R
Re: SERVICE indicator on battery disconnect
Well, all I can say is that I have disconnected the battery a few times, installed a battery tender port, charged it, and never had any warning lights come on.
Harald
2007 BMW R1200R
2007 BMW R1200R
Hi Crazy
the service light has always come up when I've disconected the battery. Annoying at first but after a while I don't notice it there.
Regards Mick
Regards Mick
Mine has not come on either. I have disconnected the battery more than a few times.hjsbmw wrote:Well, all I can say is that I have disconnected the battery a few times, installed a battery tender port, charged it, and never had any warning lights come on.
What is happening to my skin?
Air can hurt you too
Just took battery out last week, charged batt. with tender, installed it yesterday, no " service" lite here.
2005 FXDL
2008 R1200R
2008 R1200R
- Coyote Crazy
- Triple Lifer
Mine either. I have disconnected battery to wire in GPS direct to battery and did not experience any "service" or other warning lights. Since getting a service light has happened to more than one of us it would be interesting if anyone knows what causes it.hjsbmw wrote:Well, all I can say is that I have disconnected the battery a few times, installed a battery tender port, charged it, and never had any warning lights come on.
Mick, that would drive me nutsmickyt wrote:Annoying at first but after a while I don't notice it there.
Rick B. - Santa Clara River Valley, CA
Iron Butt Member 54010
2007 R1200R Crystal Gray
crazyhorse
that is weird. it's not a 'light' per se, it's the word 'service' on the LCD section to the right between the clock and the odometer.
my bike is an 08. perhaps there was a difference in model years. i should try disconnecting it for longer and see what happens, since it was only a couple of seconds that i had it disconnected.
wes
wes
The Stuck Canuck
In Garage:
08 R1200R
08 WR250R
In Garage:
08 R1200R
08 WR250R
The '07 bikes were lucky enough not to have that "feature"..
- LumpyCam
Yep, my '08 had the service indicator come on after battery disconnect too.crazyhorse wrote:my bike is an 08. perhaps there was a difference in model years. i should try disconnecting it for longer and see what happens, since it was only a couple of seconds that i had it disconnected.
I wonder if we can get this cool new feature added on to our older, woefully out of date motorcycles?
- Mollygrubber
Well, it may not be the manufacture date that's at fault, mine is an '09 (and a lovely shade of blue, I might add) and has exhibited no such behaviour after several battery disconnects...
Next theory : rampant over-farkelization leading to canbus confusion.
2010 F800GS
Member #741
2010 F800GS
Member #741
I have 100% of my electric farkels hooked non can't -bus. Installing a Cen-Tech under seat fuse box (directly connected to the battery) was one of the first things I did for my bike.
