How much slack should there be in the throttle? How do you adjust it?
thanks
73516
07 R1200R Throttle Slack Adjustment
Re: 07 R1200R Throttle Slack Adjustment
Not much. There is a thumbnut adjuster right at the cable exit on the throttle assembly. Just make sure you hear both TB's go "click" when the throttle is released (that's them hitting the throttle stops.)
