Hi
I have an R150R 2001 The protective sheathing for the wiring is breaking down and needs replacing. I was wondering if anyone had ideas to fix this. There is a product soft seal by CRC which is good to keep out moisture and maybe a black cloth tape? There are plastic coils also a black plastic (snake skin like sheath) which you would have to remove the connectors.
So and ideas would be great.
Protecting wiring
- towerworker
Re: Protecting wiring
Removing connectors may prove a daunting task plus increasing the chance of error in re-installation. Wrapping with cloth tape would be a good step, another possibility is the spiral coil like stuff you can buy at commercial electrical distributers..http://www.grainger.com/Grainger/PANDUI ... Wrap-1LEZ5
The spiral stuff from Panduit comes in different colors too. Wrap it then tape it. What ever you use should be removable without causing alot of trouble.
'05 RT
'04 R
'03 R
CB750
KZ750
HD 350 Sprint
'05 RT
'04 R
'03 R
CB750
KZ750
HD 350 Sprint
Mine did the same thing, and I first wrapped the damaged areas with electricians tape, but that only lasted a couple years. Then I stripped off all the old broken sheathing and wrapped the wiring with silicone self-vulacanizing tape and stuffed it into plastic wire looms. At the same time I moved the horn and removed its bracket which was chafing a bunch of wires behind the headlight. I think it will last as long as I need it too...
Rich
ADIOS!
ADIOS!
