rear wheel play R850R
This forum houses topics related to other BMW bikes that dont have their own forum (s1000r, r9t, K1200R, F800, r1250r, GS, HP2, HP4, F, K bikes, etc), or upcoming machines
jacksgp
Post by jacksgp »
It's rare I get my wife out on the bike but today was one of those days. She is a light weight so it's almost like riding alone. Now ...my question!
I noticed right off that my bike was not handling as usual. I thought maybe I needed air in my rear tire so I checked the pressure and all was good.
I returned home asap with about 20 miles ridden. I put my bike on the center stand and found that I could move the wheel side to side appx 1/16---1/8 of a inch. I thought maybe the lug nuts somehow loosened but that was not the case. Not Good....
Let me add that even before I rode with my wife there were times the ride seemed alittle off...not bad just something annoying at times...hard to describe!
Any suggestions? My bike is a r850r with 99,000 miles and NEVER a problem untill now!
NoRRmad
Donating Member #: 388
Re: rear wheel play R850R
Post by NoRRmad »
Uh oh. Look for metal shavings on the magnetic drain plug of the final drive.
sweatmark
Septuple Lifer
Donating Member #: 208
Post by sweatmark »
Don't fret yet.
Rear wheel play can originate in a couple of places, including the final drive bearings (that hold the crown gear/rear axle), and in the Paralever linkage joints.
Read the following for some background info, including the external references found on ADV and UKGSers boards:
<edit> added this first link for good place to start: http://www.advrider.com/forums/showthread.php?t=469866
http://www.r1150r.net/board/viewtopic.php?f=2&t=22603
http://www.r1150r.net/board/viewtopic.php?f=21&t=2003
http://www.r1150r.net/board/viewtopic.php?f=2&t=19113
http://www.advrider.com/forums/showthread.php?t=729251
http://www.advrider.com/forums/showthread.php?t=512785
http://www.advrider.com/forums/showthread.php?t=560727
jacksgp
Post by jacksgp »
Good news...no metal shaving in the rear drive! Yippeee
I removed the final drive housing and discoverd that the needle bearing on the right side are shot. The left side is fine but I will replace both of them. The roller bearings are worn so they will also be replaced also. The pivot pins are good so they will be reused!
I have two questions....
1... When I removed the bearings I did not mark what side of the bearing faces out. I do not know even if it matters but the inner race has a number printed on it. happy guy 10-6465a. I read on another site that the bearing are not the same diameter so it matters how they are to be installed! I do not remember seeing the number on the bearing before I removed it so I'm thinking the printed side faces in where you can't see it. Any thoughts!
2... I was going to check the pivot pins and bearings on the swingarm while I have everything open. Good idea or not?
Let me end by saying thanks to norrmad and sweatmark. The links that were provided were a great help and I appreciate all you done! =D>
jacksgp
Post by jacksgp »
I can answer my own question...the printed side of the bearing goes to the inside. Hope to be back on the road shortly!
machew01
Donating Member #: 345
Post by machew01 »
Good luck with your repairs. It sounds like you have everything under control.
I have always liked the R850R - they are beautiful bikes.
mac
jacksgp
Post by jacksgp »
The job went real smooth...the hardest part was getting the courage up to "take it apart". The help on this site is first rate!
The r850r is a awesome machine...not the fastest.....not the coolest...but absolutaly a solid bike. Too bad they were only imported here for two years!
sweatmark
Septuple Lifer
Post by sweatmark »
... and the smoothest oilhead for sure.
Loved my '96 R850R "Rocket" as 1st BMW. Would be fun to get another for renovation.
jacksgp
Post by jacksgp »
Agree totally...I sometimes see one on ebay or other motorcycle sites and cotempate buying another one.
What a wonderful machine!
