deilenberger wrote:Interesting comparison since you own both. I think there are two places where the Telelever stands out. The amount of travel available (real world, not theoretical which BMW likes to use, ignoring things like bumper compression) and the resistance to binding and dive (using up the travel in a non-productive way) in sub-optimal conditions - like having to brake on rough pavement on a curve.cug wrote:Not a good test in my opinion. You need to test where it really matters, when your braking distance gets worse because of the different concepts: on a bumpy and curvy road under hard braking.Bill Stevenson wrote:In short, the loss of Telelever on the new bike is a non-issue as far as I am concerned. YRMV.
I'm not a good enough rider to say with 100% certainty that I'd never have to do that.
Joe you're riding roads you're familiar with, and I'm sure you know the speed you can carry though the corners without braking. If I was riding the same roads - the situation wouldn't be the same. I think what you missed Joe - is CUG (name?) added braking in the corner (with rough pavement) into the equation.
In that sort of case - I'd want every little edge I could get, and in that case under those conditions, unless there is magic involved, telelever simply has the edge. That's due to the design. Trick electronics can't produce the same combination of anti-dive, no-stiction or binding and retaining full suspension travel under hard braking. Isn't happening. Can't actually without a whole bunch of impractical complexity.
And that's the biggie that's keeping me from trying a new R12R..
Actually, I'm pretty certain cug doesn't have his in his garage yet, so his opinion is coming from his test ride... certainly not from taking out the two bikes on the same road with a measuring tape, some marking chalk, and a camera for a real comparison. I have however taken all three generations of boxers in the garage back to back on the same roads in my hood' and pushed them hard, more than once. Not scientific, but there's no doubt the 2015 handles aggressive riding better and "emergency" maneuvers just fine, IMHO.
While I do know the roads around, there's literally hundreds of miles of canyons in my backyard, I can't know every corner and many times I've been riding more aggressive than anyone (but me )should on the street and have done dozens if not hundreds of times exactly what you guys are all talking about - braking very hard on rough surface sometimes coming into a corner. There's also the sudden corners and landslides I've been on in 3 states that I wasn't able to anticipate by memory.
My new RR has a nice ding in the front wheel from coming around a corner moving at a good clip to find a recent landslide... heavy braking, then dodging the big ones, the one I aimed for was the size of an baseball, better than the many football sized rocks options. My reactions, with the bikes overall handling I didn't crash. There's more to how a bike will handle in an emergency than just tele lever vs. forks... it's a fun debate assuming everything else is equal - it's not so therefore the debate is pointless.
It's always better to be setup correctly and carry speed through a corner of course, with thousands of miles of seriously pushing things I have tested how this bike handles in real life emergency situations, with huge cliffs to go over.... just trying to say that I don't see any major issue with this bike being just as safe and it performs better than my 07' hands down.
I could NOT say the same thing about the NineT or the F800R when comparing them to the 07'.
SO even if "technically" the tele lever can provide better stability under heavy braking, the level of performance all of the R1200R have is plenty safe in an emergency situation. If there is an edge, it's so minuscule that if someone is depending on that for their own safety I don't know what to say to that.
That edge (which I haven't felt) from tele lever in very specific situations could be mitigated by more professional rider training for sure, even if it's just a placebo.
