Suspension Setting
mzzogrno
Suspension Setting
Post by mzzogrno »
What is the best way to set the suspension setting on the R? What sould one look for?
Post by DJ Downunder »
What is the best way to set the suspension setting on the R? What should one look for?
Too soft....and....too hard................You want something in between.
Are we talking front or rear?...preload?...it depends on how heavy you are..your type of roads and the type of riding you do.
I think most of us have the adjusting screw turned fully in and then backed off about two turns...and I have my preload adjuster on the rear close to fully stiff/hard....that's how I like it....it would be a bit too stiff for most.
MIXR
Post by MIXR »
Common around here is the DJ solution as well. Crank it all up hard and then back it off a couple of turns. Seems to work with the R's stock suspension on our rough roads.
solitario11
an inch of travel?
Post by solitario11 »
I read some place that you should have an inch of travel when your seat onthe bike...... and take from there..... Is this a good idea?
Rafael
R1150R k4
V-STAR 1100 k6
Valley Cottage NY
That would be one inch of sag...sounds about right.
Mxer's have about 4" of sag...but then they have about 12" total.. :shock:
