Thick as a Grip
philm35
Thick as a Grip
Post by philm35 »
I'm looking for a way to increase the diameter of the heated grips on my Roadster. Anybody using any kind of grip cover or material to make the grips fatter?
Thanks,
--Phil
2004 R1150RA (Silver)
beemerphile
Post by beemerphile »
I've got some foam wraps that velcro on top of the stock grips to increase the diamter. Amazingly you can still feel the heat through them. I am not crazy about them, but they help. I don't remember the manufacturer.
bobclift
Post by bobclift »
I'm using Grip Puppies...
http://www.casporttouring.com/store/mer ... =Hand-Cont
I've had the wrap arounds with velcro closures but didn't care for them.
The grip puppies were tough to get on - I turned them inside out, soaped them up with a dish soap mix, tugged and pushed for a half hour - but they finally went on. They do exactly what I wanted - increased grip diameter and allow me to still feel the heat!
Good luck! Bob
philm35
Post by philm35 »
The Grip Puppies look perfect. Which size did you get?
--Phil
Capt. Blackadder
Post by Capt. Blackadder »
I recently installed some grip covers from Grip-Tek. The size I got was GCM 4.25, and they come in a bag of 6 for $15. I've been pretty happy with them. They reduce the throttle effort quite a bit, which was my main goal. A side effect, which is a bit of a minus in the Phoenix summer heat, is that these covers are warmer than the stock grips. I can't say whether they do anything for handlebar vibes, as I haven't been on any longer trips since I installed them.
philm35
Post by philm35 »
I like those Grip-Teks too. Decisions, decisions...
--Phil
bobclift
Post by bobclift »
Phil - I got the small grip puppies (but the others look great too!).
I usually ride with gloves but, IMO, in unusual circumstances that I ride without gloves, the OEM handgrips are plain uncomfortable (and leave grooves in my palms/fingers.)
I think I'd do this real soon for any BMW I purchased. Inexpensive and makes a big difference. Bob
philm35
Post by philm35 »
Bob--
I ride with gloves, too. That's the reason I want fatter grips. The gloves seem to create a lot of effort for my fingers to wrap around the grips... I end up with sore forearms after 90 minutes or so of riding. If I ride without gloves, there's no problem. I'm hoping that fatter grips will solve the problem.
--Phil
leno
Post by leno »
Sounds like a change of gloves would be an easier option. Or you could try some leather restore to soften them a bit. Saddel soap works as well.
philm35
Post by philm35 »
That's what I thought, too. I just haven't been able to find any gloves that work better.
--Phil
