How appropriate for this thread to come up.
I took off for a ride this morning and neglected to perform my usually routine check of tire pressure. I rode about 100 yards and noticed how funny the bike handled! Stopped…Got off…Checked the rear pressure. 11.5 POUNDS!!! YIKES!
I rode her slowly back up the hill to my garage and put it on the side stand. I’m thinking it’s about time I had a flat after three plus years of riding. I scanned the tire for nails or screws but didn’t see any. Then I went back over it more carefully and found these two little baby holes.
http://i81.photobucket.com/albums/j202/ ... oholes.jpg
I must have ran over something nasty on Friday ‘cause it leaked down from 40 to 11.5 lbs. in two and a half days. Not exactly a slow leak but also not a BIG gaping puncture wound. No tire shops open today…Monday…so I decide to try my trusty Stop-N-Go kit to see if it really works. What have I got to lose?
http://i81.photobucket.com/albums/j202/ ... thekit.jpg
The first thing you do is insert a small mushroom shaped plug into the end of the Gun using the end of the nozzle to push it down in there straight. It must be straight!
Then you ream out the hole bigger with the probe tool and by screwing the probe tool onto the big end of the nozzle you insert the small end of the nozzle into the hole in the tire.
http://i81.photobucket.com/albums/j202/ ... zzlein.jpg
This required some strength and finally a hammer was called upon for duty.
http://i81.photobucket.com/albums/j202/ ... rprobe.jpg
You then unscrew the probe tool from the nozzle, leaving the nozzle in the tire.
Now go back to the gun with the little mushroom plug sitting there ready for action. Put one drop of oil on the head of the mushroom…
http://i81.photobucket.com/albums/j202/ ... pofoil.jpg
…and screw the gun onto the nozzle, which is protruding from the tire. Give the gun several pulls on the trigger, and release the drive mechanism to pull the trigger some more. Release, pull. Release, pull.
http://i81.photobucket.com/albums/j202/ ... nozzle.jpg
Do this about four times and then pull the nozzle out slowly. You will see the end of the mushroom plug extending from the tire and hopefully you got it shot far enough into the tire. You will know for sure in the next step.
http://i81.photobucket.com/albums/j202/ ... plugin.jpg
The next step is to grab the end of the plug with some pliers and pull on it stretching it to about 1 to 2 inches. You’ll feel it seat.
http://i81.photobucket.com/albums/j202/ ... llplug.jpg
Trim off the end with the little knife in the kit…
http://i81.photobucket.com/albums/j202/ ... iceoff.jpg
…and Bob’s your uncle!
http://i81.photobucket.com/albums/j202/ ... nished.jpg
That wetness around the plug is the oil I applied to the inside of the nozzle, which spilled out when the plug separated from the nozzle. I just wiped it off after the job.
I had to do two holes, and since the first hole on the left was my first experience at using this, I didn’t pull the plug far enough to seat it properly. I added 40 lbs. of air and that first plug was blowing like crazy! I had to start over with the reaming, etc. but after that second try on the first hole, it plugged fine. I put 41 lbs. of air pressure in the tire and so far it isn’t leaking. I will let it set overnight and see if it still has 41 lbs. in the morning.
My final report on the effectiveness of this plug will come after I ride to work tomorrow.
Wish me luck!
