It would probably get hot enough you wouldn't want to hold it, and it might rupture from boiling / vaporization of some of the chemicals inside, but not as dramatic as vaporizing a wrench, probably.mogu83 wrote: I worked for 35 years with low voltage, high amperage DC voltage. I can show you a AAA battery cell, the size of a short pencil, that puts out 1.5V and I can show you a cell the size of a 55 gal fish tank that puts out 1.8V. I saw someone drop a pair of pliers across one of those cells once and after the flash and loud bang all that was left was some metal splatters. I don't think that would happen if you shorted out a flashlight battery. But I could be wrong.
Batteries have both a capacity for energy storage, and an internal resistance. That's the resistance the battery itself provides to current flow through it. It's an intrinsic property of the battery, but you can think of it as being in series with the actual load.
Hypothetically, if you have a 12-volt battery with a 12-ohm internal resistance (besides being a really poor battery) the most current the battery could ever source would be 1 amp. Voltage = current * resistance = current * (internal resistance + external load resistance). In this case, even if the external load resistance were zero (i.e. dead short across the terminals), you still have 12V = X amps * 12ohm ... so 12V / 12ohm = 1 amp, maximum.
In the case of the AAA vs. the fishtank, the fishtank probably has a lower internal resistance, and most certainly has higher energy stored. Even a battery with zero internal resistance can't do very much if it doesn't store much energy ... or current * voltage * time.
But ... don't disrespect those little AAA batteries too much. An AAA alkaline cell stores around 1.4 watt-hours ... or roughly 5000 joules.
A typical round from an M-16 rifle has a muzzle energy of around 1800 joules [1]. So, that little AAA battery contains more than two and a half times as much energy as delivered by a shot from an M-16!
Now that I've taken this thread this far off-topic, here's a question:
You have a car battery, some jumper cables, a model train set, and a can of beer. How do you use this to build a railgun? [2]
Good roads,
- Lewellen180
[1] Wikipedia
[2] I asked this to one of our Ph.D. students as part of a qualifying exam question....
