Starting Issue
Oilhead
Starting Issue
Post by Oilhead »
Hello, I have a 2002 R1150R. When I push the start button, I hear a click and then nothing. If I try again i hear a whine and still nothing. The whine is coming from the fuse box under the seat.
The battery is fully charged. I got a new starter relay and still the same result. I removed the starter and tested it and works fine as well.
The bike was running fine, just did a valve adjustment, started it up and ran beautifully, and I shut it off. I tried to start it a couple of days later and this happened. Any ideas? Thank you!
2002 BMW R1150R
2004 Honda CBR600RR
2006 Kawasaki KLX250S
2008 Ducati Hypermotard
1996 Ducati 900SS
Re: Starting Issue
Can we assume you've checked all the appropriate switches? Some are kinda obvious but easy to overlook. It's in neutral, kill switch to on/run etc. On center stand with side stand up and so on.
Boxer
Donating Member #: 2
Re: Starting Issue
Post by Boxer »
That click noise is usually an indicator that the battery is very weak...or possibly a battery connection is not tight. Not sure about the whine under the seat. It has been a long time since I owned my black R1150R - "The Black Dominatrix".
Oilhead
Re: Starting Issue
Post by Oilhead »
towerworker wrote: Mon Nov 18, 2024 9:41 am Can we assume you've checked all the appropriate switches? Some are kinda obvious but easy to overlook. It's in neutral, kill switch to on/run etc. On center stand with side stand up and so on.
Yes, I have checked and everything is good to go...
2002 BMW R1150R
2004 Honda CBR600RR
1996 Ducati 900SS
Oilhead
Re: Starting Issue
Post by Oilhead »
Boxer wrote: Thu Dec 12, 2024 10:03 pm That click noise is usually an indicator that the battery is very weak...or possibly a battery connection is not tight. Not sure about the whine under the seat. It has been a long time since I owned my black R1150R - "The Black Dominatrix".
The battery is fully charged and all the connection seems to be tight...
2002 BMW R1150R
2004 Honda CBR600RR
1996 Ducati 900SS
