Here at last! Timidster meets Roadster
Posted: Sun Sep 02, 2007 7:03 pm
My wait is finally over - picked up my Crystal Grey R1200R on Saturday morning, and managed to get 600km done before its first service today (it's Monday already here at GMT +10).
Farkles mostly installed by the dealer: shocks, hugger, screen, bar risers, lower pegs, swapped tyres for Z6s, and even the headlight protector. Rick, my sales guy, really went the extra mile - though sadly that was his last day.
The SIT is vastly improved by the Verholen bar-backs (risers, whatever) and the Suburban Machinery footpeg kit. The low seat is surprisingly comfy - though it doesn't look so - even if it does have its limits (300km in a sitting is stretching it, so the Airhawk is gouing with me tomorrow). The 16" Cee Bailey screen is too short, even for me (sigh) - and my BMW System 5 helmet argues vociferously with the airflow coming off it. Initially it'll be earplus (I have the ones moulded to my ear canals), subsequently a Parabellum for winter - I'll probably need to cut it down, but I've done that successfully in the past (cut the edge, trim and sand around, then polish off). I'll use the 16" around town with my Systems 4 helmets, swap to Parabellum plus foot shields to for touring.
.. and I will need adjustable levers. The span reach on the brake is too long for safety and comfort. Clutch is OK, but would benefit as well. Bummer, cheapskate BMW - you useta fit them as standard.
The RIDE is vastly improved by the Wilbers - the choppy / harsh front is now supple as can be achieved on lousy Sydney roads. Out on open country roads the ride is relaxed - this is an all-day bike (soon as I get an all-day seat). I hadn't noticed the OE rear much on test - still, the Wilbers rear is very well planted. And thanks to Peter Lucas at Procycle for a suspension tutorial and free set-up.
The MOTOR and DRIVE is everything it should be - noticably freer in the last 100km obver the first, and of course that'll get better still. At first I had to take slow bends in second or even first because motor didn't want to pull in a higher gear (and I didn't want to stress it) - that was better this mornng, so that roundabouts were second instead of first and general 60km/h running was 3rd instead of 2nd. I'd have to say the 1150 motor is more tractable low down - the 1200's fuelling as snatchy by comparison, as was the drivetrain (but that's already better and will get more so). The 1200 is still very tracatable (I was a bit worried, given the peak torque is at higher rpm) and in the right gear has a lovely smooth urge about it (especially compared to the peppy li'l 650!). Look, it's a shaft drive and that's how it is - they get a little snappy if the dummy in the seat isn't smooth.
ACS does seem to work. Not that I gave it a nudge given the low mileage, but the one or two sharper accelerations I did do showed no sgn of the front goping light or ready to lift - the test bike lifted its front wheel slightly under the sharp acceleration. The forecast for tomorrow's ride out of Sydney is wet, wet wet - so that might test the system.
HANDLING is as good as I've experienced, even with the limitations of timid rider, new bike and new tyres. No, it doesn't do city like my F650CS - I had to take the CS for a quick run after doing 400km on the R12R on Saturday and it's markedly more flickable in city conditions. The R12R is a true open road bike - at the legal limit (well ever so slightly over) it simply purrs in 6th, saoking up whatever bumps in corners or straights ... the open road feel is actually like a slow steering bike (like my R1150RS or my R80 mono) - which the R12R ain't, as you discover once you hit tight bends.
And I have on-board computer fuel fault already - "empty", even after I fill it.
I'm still getting used to managing it in the city - coming back tired in the dark on Saturday was a chore, so I confined my Sunday run to the city (still plenty of bends here in Sydney if you know where to look), and by this morning's 20km run to the dealer I could stop it exactly wher I wanted to (instead of two car lengths beforehand). I can see I'll get city-confident.
Got it home and make up an oil cooler screen - using balck silicon to stick expanded mesh to the cooler shroud. Messy inside (I'm no mechanic) but clean outside, and the silicon will stick well and still peel off clean if needed.
Decals went on Sunday morning. Bike looks so much better without 'em.
YES - I WILL POST PICS .. have already taken a few, but it'll be next week befroe I downlaod the camera and find a web location (cuurently don't have one)
