Dyno run on a Beakster
Took my 02 R1150R to a local shop that has a dyno and an exhaust "sniffer" to dial in my Techlusion. I installed the Techlusion pretty much when the bike was new to cure the "non existent" surging, which it did. I recently installed a Remus Y pipe and C F can along with a C F high flow intake snorkel and "Blue" filter element. The bike ran fine, but I wanted to see if I could make it better with some tweaking. It was pretty close, but slightly rich. After about 4 or 5 runs with pot tweaking in between I got it leaned out and running better. Final numbers were 83.7 HP and right at 100 ft.lb. torque. Not too bad, I'd say. The numbers would possibly be higher if there had been any ram air effect in play. High speed air flowing through the intake system definitely would be a plus. The bike is extremely quick and feels stronger than before.
DJ Downunder
Byrdguy
Yep.....I did the very same thing, a few years back and obtained 83.9 hp on a dyno jet. The bike had more pep and pulled clean and hard to the redline.
My set up was:
Two Brothers Racing (TBR) cat eliminator and can.
Tedchlusion at factory settings
Original air filter
3 degrees timing advance (just about all that can be had)
Autolite 3923 single electrode plug
89 octane gas
I also baselined the bike and it came in at 77 hp before the mods.
Enjoy.......
My set up was:
Original air filter
89 octane gas
Enjoy.......
Byrdguy is correct, the factory spec is 85 at the crank.
Normally these bikes have a loss of about 15% througn the transmission and diferential.
So, in my case the baseline RWHP was 77 hp X 1.15 = 88 hp at the crank, a bit higher than the spec, do remeber that the dyno's do have diferences and the engines do too.
After the mods the reading was 83.9 hp x 1.15 = 96 hp at the crank.
Beemeridian
