i need an advice..
Yesterday i syncronised tb, and adjusted the valves with a help of a guy who serviced BMW in Cro. untill 2001.After we started it up it was fine......not...... very fine, and after we think that it is a time for a test drive ..it went off....
The fuel pump run and it wouldn't stop (we notice that after a several tryouts to start the engine).....
We dismounted the fuel injectors and tried to start so we can see if the fuel is gettin to the injectors-NOTHING..
i thote that the fuel filter is jamed so we took everything appart,fuel filter ok -nothing jamed or so.
one thing do--the fuel pump had the strangest noise, it was like it was no fuel(run dry) noise, but the tank had 10l....
Now the imprtant thing.... after all te sevice and the motor running i had a grey smoke out, and it was rich with unburned fuel, you could smell it( like it had too much fuel and it couldnt burn complitley).. that happen before, when you started it it was ok, and then after a few minutes it started to smoke and smell, sometimes litle ,sometimes allot , sometimes nothing (after a good run)...
My question...
Did the fuel pump start to lose the presure and finaly broke, so i need to replace it and the smoke will disapear and the motor will start?
... or there is something else .......more deeper mater involved?
Many thanks....guys for each and every post.....it helped
