Liquid fires, like gasoline, are normally handled by a type "B" fire extinguisher.
Now our fuel is changing with 10 to 15% ethanol being added. This may change the requirements of fire extinguishers.
Anyone having knowledge in this area please share.
Here is what I came up with so far via Google:
Re: ethanol fires, google came up with several hits, this appeared the most succinct:
http://www.cstone.net/~sfcav/2007News/e ... onse05.htm
Essentially, even in 10% concentrations (common motor fuel), there are issues with foam fire equistinguishers, a special alcohol resistant polymer is necessary to prevent the foam from "burning through" and the fire extinguisher failing, especially in terms of the fire flaring back up when it appears to be out.
The quantity of fuel makes a difference as to the results as well as the ethanol concentration.
For small spills it may be that a combination B, C fire extinguisher may work, but there are issues to be resolved.
