How does a bad starter behave?
Posted: Thu Jul 31, 2008 8:47 pm
by meistre
I just replaced my battery ('04 Rock, 18K miles) because it started cranking slowly even though I keep it connected to a tender whenever it's parked. Still, after a new battery it cranks slow and won't start. The voltage on the battery shows almost 13V and the system is charging @ 14V so I'm beginning to suspect the starter ($400!). It's making a slow grinding sound which doesn't sound too abnormal but it starts clicking after the first crank or two. I guess I could pull it off and test it but I was hoping for a simpler (and cheaper) solution.
Re: How does a bad starter behave?
Posted: Thu Jul 31, 2008 10:13 pm
by duckdave
Badly.
I went through a similar thing last November. Replaced the battery and still had problems. Replaced the starter, all is good. I still haven't pulled the old starter down yet, but I suspect dirt and crud were the major bad actors. Saving that job for our next snow day.
If you want to pay less for a starter visit:
http://www.euromotoelectrics.com/
I paid $189 for a complete starter for my '04 RR (including shipping) this past November. I re-checked the price today, still the same. The new starter arrived in 2 days. I recommend calling and talking to the guy as they also sell replacement parts of starters and he can troubleshoot most problems on the phone, so you might get off cheaper.
Posted: Fri Aug 01, 2008 2:07 am
by Johnny
I also had mine replaced some time back. I would get scratching metal noise after every start which would only get worse as time went by. I had the starter taken apart and cleaned by BMW Service three or four times. It would work fine after every clean but only for a week or so. After a month of troubleshooting the starter reached a point that you could hear it rotate properly but the bike just wouldn't start. By that time I was out of warranty but since my first visit to the dealer about this issue was when the bike was still in warranty, I got mine replaced free of charge. Thank God
Posted: Fri Aug 01, 2008 2:00 pm
by meistre
Fantastic responses! Thanx for your help guys. I'll give euromotoelectrics a call. It appears that it would be a pretty quick replacement (aside from the fact that the damn fuel tank has to almost come off to access the battery!)
Thanx again duckdave and johnny!
