30k maintance,what do i need to do???
Posted: Sun Sep 28, 2008 3:36 pm
by uchy9999
i want to give my bike the 30k maintance, besides changing the oil, oil filter,final drive oil,
spark plugs,and air filter is there anything else i need to do....thanks
Re: 30k maintance,what do i need to do???
Posted: Sun Sep 28, 2008 6:26 pm
by Biff's R
check the valves, synch the throttle bodies. there is a list floating around here some where.
Posted: Sun Sep 28, 2008 7:09 pm
by iowabeakster
Depending on your ongoing maintenance, some things below may be excessively redundant...
replace the following:
oil, oil filter
FD oil
tranny oil
air filter
fuel filter
spark plugs
brake fluid
clutch fluid
Do the following:
check TB synch w/ inspection of cables for wear and resistance
check valve clearances, adjust as necessary
inspect brake system for leaks, inspect pads and rotors for wear, replace and clean as necessary
inspect/tighten wheel lugs
inspect rear wheel bearing for play, fix as necessary
inspect swing-arm play, fix as necessary
test/clean battery and terminals
clean/grease side stand pivot and switch
inspect alternator belt
inspect light bulbs, switch gear and everthing else... :D
