Instrument Lights not working...
klrstix
Post by klrstix »
Hello all,
I have a 2004 1150R with almost 19000 miles. The instrument lights have all stopped working. I have checked the fuse and it is ok. I have also pulled and replaced couple of the bulbs and that did not remedy the problem. Outside of some form of a wiring harness or connection that is bad,or worse a "short" under the gas tank :shock: what else may account for this. Your thoughts are appreciated.
FloridaBeakster
Re: Instrument Lights not working...
Post by FloridaBeakster »
Sounds like it might be from overly tight wiring routing. The stock wiring harness going to the handlebars/instruments are often tip-tied too tightly to the frame from the factory and don't have enough freedom of movement during turns. The result is broken and/or shorted wires. I'm guessing one or more of yours are broken.
-Mike
'02 R1150R
'88 R100RS
Robert_winter_1000
Donating Member #: 195
Post by Robert_winter_1000 »
I think FloridaBeakster is right... one of the wires might be broken!
klrstix
Post by klrstix »
I thought that might the primary response. Thanks for your input.
NoRRmad
Donating Member #: 388
Post by NoRRmad »
Since they all went at once, I'd be looking for the common ground wire. Are your turn-signal indicators working?
klrstix
Post by klrstix »
Yes, Turn Signals are working...
