OMG! We Have TINY (Spline) Shafts!
dnat928
Post by dnat928 »
With the continuing saga regarding the clutch spline shafts, I was inclined to take a peek at mine. I have been a regular reader of the various topics relating to those that failed, those with wear and those still clean and sharp. Intriguing was the topic that provided a way to look at the spline shaft by removing the starter. Last weekend's oil change got me into the cycle-work mode. Removing said starter, there it was. And to my amazement - it was TINY! I was shocked and emmbarrassed!
Apparently, all those posts about spline shafts - with photos - were CLOSE-UPS, giving me the impression that our shafts were BIG. OK, as a mechanical engineer, one look was all I needed...no doubt, these things are way too small, aside from all the other issues on lube and alignment.
Just to get a feel for possible wear, I did the clutch-play exercise to see of there was a growing gap between the spline components. Per the thread, play of about 1/8" at the outer edge of the clutch plates was nominal/low. My check showed that or less. Also of note: those photos of failed splines seemed to have a fair amount of iron oxide powder in the vicinity of the splines. One thread noted that upon loss of lube properties, oxidation commences - and iron oxide powder is itself an abrasive, hastening wear on the spline surfaces. Of note - there was no iron oxide powder in the area and my spline was shiny. A dental mirror check saw no undue wear or indications of wear. I feel better now, but a full disassembly and lube is still somewere in the not-to-distant future...now at 49k miles.
Member #1058
AndyRR
Re: OMG! We Have TINY (Spline) Shafts!
Post by AndyRR »
I had the same reaction when I first saw the splines in person. I should have given it some scale before. If your measurement was at the toothed edge of the flywheel, you have about 1.5 degrees of backlash. If I am reading you right, you measured 1/8" at the edge of the clutch. With an approx diameter of 164mm that gives you about 2.2 degrees. My splines had not yet failed and were at 5.1 degrees.
I was about to suggest that you take a closer look before spring gets here, but then I noticed your location. Nevermind - ride it.
NoRRmad
Donating Member #: 388
Post by NoRRmad »
GadZ! Considering that about 85 pounds-feet of torque goes through that.. That is tiny!
Beemeridian
Donating Member #: 477
Post by Beemeridian »
11
cricman
Post by cricman »
"U.S. Currency
The Counterfeit Detection Act of 1992, Public Law 102-550, in Section 411 of Title 31 of the Code of Federal Regulations, permits color illustrations of U.S. currency provided:
* The illustration is of a size less than three-fourths or more than one and one-half, in linear dimension, of each part of the item illustrated
* The illustration is one-sided
* All negatives, plates, positives, digitized storage medium, graphic files, magnetic medium, optical storage devices, and any other thing used in the making of the illustration that contain an image of the illustration or any part thereof are destroyed and/or deleted or erased after their final use"
eric
AndyRR
Post by AndyRR »
fixed
NoRRmad
Post by NoRRmad »
:lol: :lol: :lol: :lol:
Beemeridian
=11
awagnon
Post by awagnon »
dnat928 wrote:OK, as a mechanical engineer, one look was all I needed...no doubt, these things are way too small, aside from all the other issues on lube and alignment.
Not only are they small, but they only engage the clutch splines by about 2/3 rds which makes their effective size smaller. I assume as a mechanical engineer, you wouldn't have made them too short either.
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
sweatmark
Septuple Lifer
Donating Member #: 208
Post by sweatmark »
The extended spline shaft option is intriguing:
http://www.advrider.com/forums/showthread.php?t=301863
Project initiator GSaddict states that he received deposits for only 2 input shafts.
Mech.engr. 6th sense (hex-sense?) is telling me that Mrs. Sweatmark's 26k miles Roadster has some sick splines that will need TLC this season. My 15k Rockster is still too young for regular spline-oscopy, maybe next winter.
Thanks to AndyRR for the great pics and troubleshooting references in his thread.
awagnon
Post by awagnon »
The improved ( ie, long splined ) input shaft has been discussed on various forums for over a year. To my knowledge, no one except the guy that makes them has gotten one. At first he needed five orders to justify a production run. Now it's 10 and he still hasn't sold any. I would have purchased one when my splines failed last winter, but he wasn't making the new shaft then, either. Even if he did manufacture them, there is still a question whether the new splines will still fail if there is a significant misalignment between the shafts. Perhaps it will just last 1/3 longer since more of it engages the clutch plate.
Al
Ogden, Utah
2002 R1150RT
2004 R 1150GS
Sunbeemer
Donating Member #: 593
Post by Sunbeemer »
I thought the same when I saw a picture of the shaft being pointed to with a pencil eraser, and thought it must have been a photographic illusion - I couldn't believe BMW would under-engineer such a stressed member. :(
