Cheat Sheet - Maintenance Items
Posted: Sun May 03, 2009 9:49 am
This has been posted before, but it might be of help to the new owners....enjoy
http://www.oilhead.com/pubs/BMWCheatSheet.pdf
Re: Cheat Sheet - Maintenance Items
Posted: Sun May 03, 2009 11:08 am
by harveyrawn
That's neat, thanks. Do you have a similar sheet for maintenance intervals? For airheads, we had minor and major service intervals. Are there similar ones for R1150Rs?
Posted: Sun May 03, 2009 11:36 am
Good and useful information. However I didn't see any information on checking the antifreeze in the R's radiators.
Wayne
Posted: Sun May 03, 2009 2:30 pm
by Roxster
[quote="towerworker"]Good and useful information. However I didn't see any information on checking the antifreeze in the R's radiators.
....there is a check valve under the gas tank in front of the battery but behind the fuel injection computer. Only way to get to it is to pull the tank off the bike...
Disclaimer: The above comments are unture and are posted strictly in fun. All attempts to check the antifreeze level by removing the tank will result in failure of said task and the loss of a perfectly good afternoon.
Posted: Mon May 04, 2009 6:43 am
"Disclaimer: The above comments are untrue and are posted strictly in fun. All attempts to check the antifreeze level by removing the tank will result in failure of said task and the loss of a perfectly good afternoon."
Are you by chance an attorney?
Posted: Thu May 07, 2009 10:01 pm
by bikermeow
Just saw that the engine oil recommended is 4 quarts. Isn't that too much? I can recall reading that it shouldbe 3.7 quarts with oil filter and 3.5 without. Anyone has the low-down on this?
Cheers
Posted: Thu May 07, 2009 10:13 pm
My maintenance manual (BMW) says "without filter-3.7qts (3.50 litre) with filter--4.0 qts (3.75 litre)
I put 4 qts in it and ride.
