As (bad) luck would have it, I picked up a 3" nail in the rear tire and as it already had 15k on it, I changed it out. It is, however, perfect to practice tire repair on. here are some pictures.
Here's where you start.
The reamer from the inside. It's a lot harder to push through the belts than I thought it would be. A T-handle would be better.
Installing the plug in the barrel.
The tool is assembled to the nozzle and pushed through the tread. The more you ream the easier this step would be. I had a struggle with it.
Insert the allen wrench and turn it all the way in. This installs the plug in the tire.
I gave it a feeble little tug and here's how it looked. There was a 1/8th inch gap under the head of the plug. It would probably leak.
Here you can see how much further the plug is pulled out. It is now correctly seated inside the tire.
You can see the head of the plug can't really set completely flat because of the ribs inside the tire. I believe a little tire cement would help seal the plug.
Here's the flush cut off. Do NOT pull on the stem when you cut it or it will pull back into the tire and probably fail.
There we go.
