07 R1200R Throttle Slack Adjustment
Post by 73516 »
How much slack should there be in the throttle? How do you adjust it?
thanks
73516
Re: 07 R1200R Throttle Slack Adjustment
Post by deilenberger »
Not much. There is a thumbnut adjuster right at the cable exit on the throttle assembly. Just make sure you hear both TB's go "click" when the throttle is released (that's them hitting the throttle stops.)
