Need help deciphering number on transmission
Posted: Sun Sep 05, 2010 1:35 pm
by macx
Does anyone know how to decipher the number, probly a part number?,
that's stamped on the upper right side of the bellhousing?
My roadster trans has a 10 digit combination number and letter code,
but no part of it matches the transmission assembly number, or the
transmission front cover part number, for my bike in the parts fiche.
I am in contact with someone who has an 1150GS trans but doesn't
know if it's the regular or low ratio trans, it's still in the bike but his
engine is blown up.
Per the parts fiche, the regular GS can have either, and the GS Adventure
can have either, also. If he doesn't remember any mph to rpm in 6th
so I can figure it out, he's going to send me that 10 digit code.
Would appreciate how to figure it out.
The code on my 04 R1150R is 00027S2JAS, nothing like the parts fiche
listing for the trans assembly which is 23 00 7 677 008, or the front trans
cover assembly 23 11 2 332 967 or 333 072.
Thx!
number you gave is Transmission serial number not part numbe
Posted: Wed Nov 10, 2010 1:40 am
by dc10bill
The number you gave appears to be transmission serial number not part number of transmission as number you are seeing is just behind timing plug on rh side of transmission case as "000####JAX" (is for 2004 R1150RT's) and your #'s has same style
Re: Need help deciphering number on transmission
Posted: Wed Nov 10, 2010 7:59 am
by macx
Since I posted that question, I finally did find an interpretation of that
code.
http://www.advrider.com/forums/showpost ... ostcount=7
Posted: Wed Nov 10, 2010 11:43 am
by f4tweet
My transmission in my 02 R 1150R is GAL. Any ideas?
Posted: Wed Nov 10, 2010 1:11 pm
by macx
Well, that's a code not listed in the document where I found
the codes. The list I found shows the 2003 & up starts with
the letter J, the ones before 2003 start with G, but it doesn't
show a GAL. The 03 & up list shows a JAL as being the low ratio
unit, so maybe yours is?
You could tell pretty easily by rpm in 6th gear. With the 2.82
final drive, the "tall"/standard ratio trans will have 21.3 mph
per 1,000 rpm, the "short" / low ratio trans with have 18.7
mph per 1,000 rpm. So at 60 in 6th, the high ratio will be
about 2800 rpm and the low ratio will be about 3200 rpm.
This is originally in German, I used Yahoo Babel Fish automatic
language translator to get an English version.
http://babelfish.yahoo.com/translate_ur ... =Translate
If it doesn't come thru in English, or not at all, here's the link to the
German language version
http://powerboxer.de/index.php?optio...364&Itemid=157
To translate, look for (free) Yahoo Babel Fish translator.
Open the German webpage, then the translator and copy the
address from the German page into the window on the translator
page. Grammer and wording comes out a little funky but you
can tell what the meaning is.
Here's a spreadsheet I made up to compare road speeds & rpms
of the standard ratio trans & final drive with other combinations
including 2.75 & 2.62 final drives and the low ratio transmission.
Hope you can figure it out! :-)
http://www.mediafire.com/?vb149e3b3548b8v
Posted: Wed Nov 10, 2010 4:41 pm
by f4tweet
Thanks. I bought this bike from a dealer. One of the mechanics was selling it through the shop. It has a high 1st and a high 6th. I swapped out the final from a 2.82 (31/11) to a 3.0 (33/11). This bike had some Police flashers and stuff on it, so he might have gotten the trans from a Police bike. If you find out any more, let me know. Thanks.
Posted: Wed Nov 10, 2010 6:05 pm
by macx
That could be.
I found out that all RTP bikes don't necessarily have the low ratio
trans like I had read when I started researching.
If you look in the online parts fiche, it looks like even the GSA's don't
automatically have the low ratio trans. It lists both the hi and low
ratio trans for them and actually for many of the R bikes.
They also make a trans with the hi 1st and low 6th - that's got to be
the worst possible combo.
