GS TOP CLAMP ON THE R?
Posted: Fri Feb 18, 2011 11:54 am
by blanc
Hi
Is it possible to mount the GS clamp and bars on the r1100r/.850? Steve
Re: GS TOP CLAMP ON THE R?
Posted: Fri Feb 18, 2011 8:21 pm
by omg1010
Depends on if you own the old R1100 model or the facelift (applied from late 1997). In principle it should be possible but the instrument cluster is not compatible to this. You could possibly use the GS-clamps but then what do you do with your instruments? Furthermore you need to check what handle bar to use and if the cables are long enough. If you use a handlebar conversion sold by for example Wunderlich you can be sure it fits ...
Brgds
Oliver
