jack location to lift front end
r12gecko
Post by r12gecko »
Where's the best place to set a jack to lift the front of the bike? Tire change for front & back planned in next short while - waiting for dynabeads to arrive by mail...
Thanks.
mogu83
Re: jack location to lift front end
Post by mogu83 »
Assuming your planning to take the wheels off for a tyre change. Do you have a center stand? If you do I've had both my wheels off at the same time for tyre changes using only the center stand with no major drama. I do put a piece of 1 inch wood under the stand just to get a little more clearance.
r12gecko
Post by r12gecko »
Do you sit a piece of wood under the front forks or under the engine? Is there a wheel you remove first for better balance of the bike? She can't sit on the centre stand alone, I wouldn't think...
mogu83
Post by mogu83 »
Again I have to assume that's a positive on the center stand.
I put the piece of wood under the center stand (takes a mighty heave to get it up). I removed the front wheel first and put a wooden box under the front forks (just in case) when I removed the rear wheel. Not a big deal and good training if you ever have to do it 'on the road'.
r12gecko
Post by r12gecko »
Thanks, I do have a centre stand.
I just find it a bother to work with load on the front end, slight as it is.
Dad2g5
Post by Dad2g5 »
floor jack with a piece of wood under the engine. Thats it
the wood under the centerstand helps too(gives u more clearance for the rear wheel)
AHHHH to ride
tobes
Post by tobes »
That's the method I use. Works fine.
IMG_3949 by mikeburawski, on Flickr
Mike
