First 2000 miles on the R1200R review - A compromise to far?
Posted: Sat Jul 09, 2011 4:38 am
I have now played with my 2011 R1200R Classic for 2,000 miles and whilst I love the bike I find in many areas it is a compromise too far and is forcing me to look at high cost modifications. The bike is, for now, stock standard with ASC/ESA/Akrapovic Can/BMW TopBox/BMW Side Cases.
My previous recent bikes have been Buell XB1200XT Ulysses, BMW R1150GSA (2 - total 50,000+ miles), BMW R1150R Boxercup Special Edition.
Firstly, few after market accessories fit the bike. I had to go with the BMW Side Cases & TopBox as none of the after maerket suppliers as yet provide fitting kits for the latest modeol R1200R. This I am sure will come in the near future but has left me with panniers and topbox which are all style over function. You can get a full face in the topbox but it leaves no space for anything else let alone attempt to put a laptop in it!!! I tried an Illimberger hugger which was meant to be the only one that provided, out of the box, support for ASC but there has been a design change with the introduction of ESA which means that it will not fit on an ESA model (danger of wearing through the ESA cable). I was unable to find an OEM small screen so had to go for the BMW version at BMW prices.
I love the responsiveness of the engine and the way that it is not sluggish in running through the power range. The vibration that was evident in my 1150RT and 1150GSA's at 4500rpm is still evident though not as pronounced. The mirrors are as useless as the Buell's mirror - all you can do is see the shape of the cars behind with no clarity as to see if they have blue lights mounted on top. The roll on above 4,500 is wonderful (which is pretty near the top of the Buell's useable power range).
The bike is a stunner for all the magazines say. Parked up besides Ducati's and the 1200S onlookers come over and look at the strange beast that does not look like a plastic toy. Even strangers in the street stop to look. Makes you feel good.
But what are the bad points? The handling is rubbish and I just wish I did not have ESA so I could replace the suspension. The issues seem to be related the the length of the chassis, the seating position and the lack of weight over the front end.
Firstly, I have noticed a tendency for it to step out at low speed of right hand bends when turning the wick-up. I know that this is the torque from the shaft drive but the frequency of it and the speed of rear end stepout even made me question if I had my foot on the rear brake. I believe that the quality of the rubber (those round things) may have an impact as when they warm up the problem disappears but that should not be that neccessary on a bike of this power/torque that is made for the street.
Secondly, it does not turn in that quickly. I know the Buell was a faster turning bike but I find the headstock angle compromises the turn in more than it did with the GSA. The GSA, from memory, seems to have been a faster turning bike.
Thirdly the bike is incredibly sensitive to weight distribution. At high speeds if you are too far back the front end road contact decreases both in weight and surface area which is not helped by the lack of feel that comes from a telelever front end. This means that above 110mph (indicated) the bars start to shake and the front end becomes very loose. Self preservation (fear!!!) forces you to back off. Replacement of the steering damper with one which is adjustable would probably remove the shake but would compromise low speed turning and is not going to increase the front end contact area or weight on the front. I have also found that the bike is incredibly sensitive to the weight in the topbox or if the topbox is mounted (leverage principle as the mounting is very high). It has been suggested that with the topbox or even without I could ride with Sports/Pillion/Luggage setting to raise the rear end to apply more pressure on the front. The problem with this approaches (raising rear end & moving weight forward) is that it lightens the load on the rear end which will make the bike more likely to step-out to the rear. Anyway what is the point of ESA if you have to ride on one setting only! The big warning from this is DO NOT OVERLOAD THE TOPBOX.
None of this is helped by the footpeg positions. The standard seat (which forces you forward) means that it is really not comfortable for riding more than 1 hour at a time. If you are forced into a forward position the footpegs need to be moved back. Of course moving them back and moving the body forward means that the bars are no longer comfortable. They are pretty wide as standard and the bar end weights are pretty heavy. I would not recommend replacing those bar end weights with the OEM silver versions which are much, much lighter and result in increased vibration.
But, and this is a big but, I love the bike. It seems that I am going to have to learn to ride it differently. Maybe something can be done with the suspension. I am visiting a suspension expert next week to see & I am also changing the seat to one which will give me freedom to move around (a 2010 R1200R seat reshaped and recovered). I am also going on a track based training day so that I can play around with the most appropriate style (California Superbike School). With this I have dropped down to the Level 1 Beginner Class (from Level 4) so that I can relearn or learn a new style. And perhaps I will not be able to do the speeds or times on a track that I used to be able to do with my 1150GSA (alloy wheels, Bitubo front & rear shocks, Staintune, whole bike lowered by at least 2 inches) which will be a shame but I am sure that I will find different ways of enjoying the bike.
My conclusion is that it is a lovely bike. The Buell handles better but the quality is poor and things keep on breaking. The GSA was a better overall bike but is so, so heavy and not really useable in an urban environment. Also there are two many "World Travellers" with GSA's all dressed up in their mega endurance gear pretending that their 2 mile trip to the local shops is the completion of the 150,000mile journey they have just ridden in their imagination. I was happy with the GSA when it was different and had a metal rather than a plastic tank and there were not many around... It was just too big and heavy! With the R1200R Classic I get most of what I want - I just need to be comfortable at high speed with it....
