sat nav
Posted: Tue Mar 27, 2012 11:10 am
Hi. where are you lot connecting your sat nav power supply to. My GS had a connection near the headstock. What about the r1200r? Cheers
Welcome to r1150r.net, your largest online source for all things R-R!
https://www.r1150r.net/board/
Do you mean that the power was turning off after the bike was still running? Mine shuts off after a few minutes which I understand is the way the port is designed. I've never had any issues with my GPS charging while the bike was running so just wondering.SF_Hooligan wrote:...apparently charging the phone uses more juice than that connector is supposed to supply. The system kept shutting off power to it...
I think it's fine for twisties and whatnot. I'll admit, although it pains me to do so, that I may need a bit more of a screen for long freeway trips - like on the way to the twisties. I don't get any real buffeting or anything, but my helmet is loud as hell.SteelD wrote:Hooligan, what do you think of that screen on the R? (sorry to hijack the thread)
Nope - it would shut down spontaneously while the bike was running and I was riding. I understand that's what the Canbus does when the draw is out of line with expectations. Turning the bike off, waiting a couple minutes, turning it back on would bring it back temporarily.devguy wrote:Do you mean that the power was turning off after the bike was still running? Mine shuts off after a few minutes which I understand is the way the port is designed. I've never had any issues with my GPS charging while the bike was running so just wondering.SF_Hooligan wrote:...apparently charging the phone uses more juice than that connector is supposed to supply. The system kept shutting off power to it...
Thanks,
Darcy
SF_Hooligan, you experienced this symptom with only the iPhone charging?Nope - it would shut down spontaneously while the bike was running and I was riding. I understand that's what the Canbus does when the draw is out of line with expectations. Turning the bike off, waiting a couple minutes, turning it back on would bring it back temporarily
Yes, I experienced this with only an iPhone charging - nothing else connected. Seemed strange, so I double-checked everything but it still occurred. I was heading out a on a trip, so I just wired straight back to a Touratech TPS 15 and had no further issues - had two Powerlets up front and have run the iPhone and GoPro at the same time with no issues. Certainly could have been a shaky connection on my part or a bum connector, but I didn't feel like messing with it. I've had zero issues running lots of stuff from the TPS 15, though.BLAIR1200R wrote:SF_Hooligan, you experienced this symptom with only the iPhone charging?Nope - it would shut down spontaneously while the bike was running and I was riding. I understand that's what the Canbus does when the draw is out of line with expectations. Turning the bike off, waiting a couple minutes, turning it back on would bring it back temporarily
I was going to install a power outlet this weekend and direct connect it using a repair connector to the factory GPS plug. This way I can plug a USB adaptor into the outlet and power Apple products.... this won't work?
...clock is ticking on our trip date and would hate to think I have to start over on the connection plan
OK, thanks ... this seriously sux. I think I'll go ahead and make the connection and see what happens... then if it fails, decide if I want to mess with the electrical only days before departure...Yes, I experienced this with only an iPhone charging - nothing else connected. Seemed strange, so I double-checked everything but it still occurred. I was heading out a on a trip, so I just wired straight back to a Touratech TPS 15 and had no further issues - had two Powerlets up front and have run the iPhone and GoPro at the same time with no issues. Certainly could have been a shaky connection on my part or a bum connector, but I didn't feel like messing with it. I've had zero issues running lots of stuff from the TPS 15, though.
Yeah, again - it could be something specific to the plug I got, etc. I really don't know if an iPhone takes more juice than a normal GPS when charging/playing music/running Navigon/looking for nonexistent cell signal. Maybe?BLAIR1200R wrote:OK, thanks ... this seriously sux. I think I'll go ahead and make the connection and see what happens... then if it fails, decide if I want to mess with the electrical only days before departure...Yes, I experienced this with only an iPhone charging - nothing else connected. Seemed strange, so I double-checked everything but it still occurred. I was heading out a on a trip, so I just wired straight back to a Touratech TPS 15 and had no further issues - had two Powerlets up front and have run the iPhone and GoPro at the same time with no issues. Certainly could have been a shaky connection on my part or a bum connector, but I didn't feel like messing with it. I've had zero issues running lots of stuff from the TPS 15, though.
I've been reading the posts, but didn't see the flag until now ... all sorts of other devices get powered by the factor GPS connector it seems... extreme bummer that the iPhone jacks it up.
Thanks again for the info... once again, great forum.
