Did Valve adjutment and found this inside right valve cover
Posted: Sun Jul 22, 2012 10:20 pm
by muamero
Removed left did valve adjust no problem. Moved on to right and immediately up on removal this dropped in the oil pan.
photo hosting
its rubber I believe,bike currently has 11k on it I owned it since 4k. Anyone has any clue what it is or where it came from
Re: Did Valve adjutment and found this inside right valve co
Posted: Mon Jul 23, 2012 2:48 am
what diameter is it?
Posted: Mon Jul 23, 2012 5:09 pm
by muamero
Half inch bro, nothing unusual going on with the bike at all. No noise, leaks, oil pressure up right on start up. What gives?
Posted: Tue Jul 24, 2012 3:04 am
muamero wrote:Half inch bro, nothing unusual going on with the bike at all. No noise, leaks, oil pressure up right on start up. What gives?
tbh, I've no idea - never seen anything like it (that I can remember). But having the diameter may help someone else figure it out. :)
Posted: Tue Jul 24, 2012 6:54 am
by gregor
By 'oil pan', did you mean as in American terminology the sump ie the finned casting underneath the engine ? I'd guess it is a part of a rocker cover gasket. Maybe left over from a previous strip down.
Posted: Tue Jul 24, 2012 10:29 am
Looks like FOD, no relation to bike. Took a quick scan through the parts fiche just now, looking for anything that might resemble your mystery part. Nada.
So, my guess is that it's something inadvertently picked up by the valve cover when the valves were done in the past.
Posted: Tue Jul 24, 2012 11:29 am
It sure does look like FOD*. Possibly a broken piece of a cap retainer lanyard like would be on a small lens cleaner or special lube oil bottle.
* ForeignObjectDamage - - an aviation term for small stones, twigs, metal/plastic/glass/rubber pieces usually blown or dropped onto the runway/taxiway/paved areas.
Posted: Tue Jul 24, 2012 12:03 pm
by sjbmw
It looks like the ring that some oil bottles use to keep the cap on the bottle after opening.
It appears as disconnected from it's cap.
Posted: Tue Jul 24, 2012 12:58 pm
On second thought, that has to be the missing part needed to make the mystery rear subframe loop effective as bottle opener.
Posted: Tue Jul 24, 2012 1:15 pm
by muamero
Thank you guys, that's the answer I was hoping to hear. And no when I said Oil pan I meant the pan I put under the bike to catch oil that spills out.
Posted: Wed Aug 01, 2012 9:44 am
by Oilhead
So the clues are it's 1/2" in diameter, made of rubber, and it looks like the original color was black...
My guess is that it must be the other end of the brake/clutch bleed screw nipple cover. Not the cover that goes over the bleed nipple but the other end that goes under the screw to prevent losing the nipple cover.
Posted: Wed Aug 01, 2012 10:07 am
by Keppelj
Interesting puzzle because it does look so very familiar. Lanyard for the bleeder sounds right enough, but the model in my mind's eye for that thing is bigger than that.
