Allen wrench to tighten mirrors
Ebet
Post by Ebet »
Does anyone remember if it's a 6 mm Allen tool that you need to tighten the stems for the R1150R's mirrors? I think I am going to buy a "Topeak Supreme Folder" to carry around for things like fixing loose mirrors, and I want to be sure it has the right size Allen bits. The ones it has are 2 mm, 3 mm, 4 mm, 5 mm, and 6 mm. Thanks!
Ebet
2004 Ferro R1150R
gel9001
Post by gel9001 »
Its Torx, not allen. The key is in the took kit I believe its a T25.
Gene
rdsmith3
Donating Member #: 74
Post by rdsmith3 »
No, it is definitely a hex wrench that is needed to tighten the mirrors, at least on my 2002. I am pretty sure it is 6 mm.
I think that the windscreen mounts also use 6 mm, so a good ball end 6 mm wrench is very useful.
mdouglas
Post by mdouglas »
If it's a hex, then it is definitely 6mm.
gelbe Kulter
Post by gelbe Kulter »
A short walk to the garage confirms that it is 6mm hex. 8)
Badger
Post by Badger »
A ball end 6mm will do the trick...I carry one...tightens mirror and windscreen.
PearlyWhite
Tight vs. Vibrate
Post by PearlyWhite »
Did you think you'd see that Subject on this bb, did ya?
Anyhow, does tightening the mirror eliminate vibration on your bikes? My left mirror vibrates to the point that I cannot discern the make/model (if it's a crown vic or not) :x But not so much for the right mirror.
Any ideas?
rdsmith3
Post by rdsmith3 »
in my experience, tightening the mirror does not make it vibrate less
if you see flashing lights in the mirror, blurry or not, then you might want to stop
As an aside, I noticed that my local PD stopped someone, and the cop was in an unmarked white Dodge Durango. What the ? That's not fair. They should only be allowed to drive Crown vics, and old people with blue hair should be prohibited from owning Crown vics.
John, 02 Red 1150
Mirror
Post by John, 02 Red 1150 »
It is a 6 mm hex. Mine will get loose everytime I wack it backing out of my garage. Also, add to your kit a 9mm if you use the chrome oil filler cap. As far as vibration, it usually just the left side mirror. It was discussed earlier and fell under the "THEY ALL DO THAT" category.
gel9001
enough
Post by gel9001 »
Enough, its 6mm hex for pre 2004 and Torx T25 for 2004, 05
thats what I say and I'm sticking to it.
Gene
jamming
Post by jamming »
When my left mirror gets too blurry, I know its time to adjust the valves and a TB sync, I look at it as Ruby's ( my Red Roadster) way of telling me she needs a little TLC.
What can I say, I'm an optimistic cynic.
Roger
mirror vibration?
I too noticed blurred images in my left mirror and relatively clear vision in the right.
My right eye is better than the left so I just switched the mirrors.
Things are so much clearer now!
03 r
Ebet
Post by Ebet »
Thanks, guys!
- Ebet's Bike
2004 Ferro R1150R
mistercindy
Post by mistercindy »
6mm for both the mirrors and the BMW screens (sport and touring). And I don't tighten the mirrors to prevent buzziness. I tighten the right one to make sure it doesn't get so loose that it flops down while I'm riding it. A little tug every couple of weeks does just fine.
And shouldn't an allen wrench work as well as a hex wrench?
'05 R1200GS
Once owner of an '03 R1150R
Member #333 (cool number!)
CARTEEUSMC
MIRROR
Post by CARTEEUSMC »
Yes, they all do that. Left mirror is always loose. I tighten mine every three rides.
Cartee
Greenville, SC
04 R1150R
Clint Cartee
Boxer
Donating Member #: 2
Post by Boxer »
No reflection on this thread, but you don't even need a hex or any other wrench to tighten the mirrors. Stick you finger up in there to hold it steady and rotate the mirror counterclockwise to the appropriate "loose" position and then while you keep the finger on the bolt head, twist the mirror back clockwise to tighten it. If you got it in the right place "counterclockwise" then it'll tighten up by hand at exactly the right spot.
It DOES take a little fiddling sometime, but it works!
Donating Member #: 312
Post by boxermania »
Boxer.....your mental acumen reminds me of a ride that we took with some friends, a couple of them where Harley riders........well upon a stop for gas one of the fellows noticed that his rear brake lever had fallen off???
He became highly worried, snce we were about 120 miles from home.....l we had to do some serious convincing that if one were careful, it was OK to ride the bike home with the front brake only.........after a while he agreed upon.....but not before I had agreed to ride his bike home if he didn't feel comfortable......heck, my problem wasn't riding his bike home, it was the fact that he had to ride mine and I didn't want that to happen......
Well, we made it home after all, we left the ensuing kidding for another timely ocassion........ :lol: :lol:
