I was cruising at 50 mph on an asphalt road when I encountered a long, deep pot hole in the asphalt. I successfully avoided that one but the avoidance maneuver lined me up exactly for another one which I could not avoid. The result was a bent lip on both front and back wheels. The bike never lost directional stability (amazing!) and the tires never lost air, but I could feel the resulting imbalance.
My Haynes manual says never try to repair a bent alloy wheel; replace it with a new one. My riding buddies tell me of several people they know who have bent rims in similar circumstances and had them very successfully repaired by wheel speciality shops. So now I am in a quandary. New wheels are very expensive - almost $2,000. Wheel repair is advised against by the manual.
I would very much appreciate hearing from members who have had this experience of a bent rim and had it repaired. I am certain there must be others out there who have had similar experience and have good advice for me. I am also wondering if there is other potential damage I should look for.
Thanks in advance.
Maccraith
'03 R1150R
Bent alloy wheel rim repair
'03 R1150R
Re: Bent alloy wheel rim repair
I've had a pretty badly damaged rim repaired in the past (Ducati TL600/Pantah front wheel). No problems at all afterwards.
Can't really help with a recommendation as I had it done by Hagons, in London (UK!).
http://www.framestraightsystem.com/Moto ... Repair.htm
Have no experience. I just saved this link in case I needed the service.
Buckster '03R
#543
#543
I've never used the service but heard good things about Woody's wheel works throught the moto community.
http://www.woodyswheelworks.com
Brett
New wheels are prohibitively priced hence that is not your option of choice. Instead look for a used one at egay or beemerboneyard or any of the other salvage specialists. And yes forged wheels can be repaired under certain circumstances. It just requires some company who know what they are doing.
I do not know of any addresses in the US of A but here in Germany there are a few companies who do this on a very professional level.
Brgds
Oliver
Brgds
Oliver
