Oil Color - is it supposed to be this dark?
ekyang
Post by ekyang »
Hey everyone,
Just took delivery of my '04 R1150R 3 weeks ago. Previous owner mentioned that he had just changed the oil on the bike. I lifted it up on my centerstand and haven't even put 200 miles on it yet when I shined a flashlight on the oil level window: Image
The previous owner mentioned that he had just swapped out the oil with a brand used specifically by Harley owners (he was a former Harley rider). My question is - is fresh oil supposed to be that dark? The oil was supposedly changed less than 300 miles ago and I'm expecting to see a more translucent color (more golden yellow) vs. the dark soy sauce color. Is this color indicative of a fresh oil change of any known brand?
Also is it normal for the top of the oil filter to be exposed like this: Image
I'm not used to seeing the oil filter exposed without some kind of cover on the underside to protect it.
omg1010
Re: Oil Color - is it supposed to be this dark?
Post by omg1010 »
NO! After just 200 miles the oil is not supposed to look like this! If I was you I'd drain whatever stuff the previous owner had filled in and replace it by some decent 15-50 or 20-50 stuff.
And yes, the oil filter is not covered.
Brgds
Oliver
swamper
Post by swamper »
I would just change it and the filter just for peace of mind. The oil usually does get pretty dark however between oil changes, 3-4K. I think air/oil cooled engines make for the darker oil color. I'm running Bosch filter with 20-50 Valvoline 4 stroke motorcycle oil. Get the filters from Beemer Boneyard by the six pack with new crush washers, good deal.
IBA#7147
BoxerSteve
Donating Member #: 879
Post by BoxerSteve »
+1, the first thing I do after buying a used bike is change all the fluids, no matter what maintenance the PO says has been done.
ekyang
Post by ekyang »
Allright - after reading omg1010 and other riders' responses I went ahead and drained the oil/transmission/final drive fluids this afternoon. That oil was some of the darkest stuff I've ever seen. No way was that oil changed in the past 2k miles, much less 200 miles. Transmission fluid was so-so but the final drive looked ok. At any rate, flushed them all just to be on the safe side. For those of you that want to know where the fill and drain holes are for the transmission and final drive on a '04 R1150R, check out below:
Final Drive fill hole: Image
Final Drive drain hole: Image
Transmission fill hole (am using hammer handle to point to the area: Image
Transmission drain hole (located just beneath where the ratchet handle is pointing: Image
ekyang
Post by ekyang »
Next up charcoal filter lobotomy.
Boxer
Donating Member #: 2
Post by Boxer »
Please take another picture in 200 miles and let us know what it looks like. I think you will find it dark again.
I put 80,000 miles on my 2003 model and changed the oil many times. It was always dark again almost immediately. I worried about it the first few oil changes but after that I found something else to worry about.
ekyang
Post by ekyang »
Really? Good to know. I'm using Mobil 1 synthetic so we'll see what the oil color looks like in 200 miles. Now you've got me really curious if I should be seeing dark oil "normally".
gregor
Post by gregor »
Looks like engine oil has spilled on to the gear box exterior and been baked on to make the paint that colour. Exhaust has had something on it as well.
That dirty oil filter looks older than 300 miles as well.
As said above a full fluid change is a good idea and a thorough clean up of the casings would reveal any further leakage problems.
BoxerSteve
gregor wrote:Looks like engine oil has spilled on to the gear box exterior and been baked on to make the paint that colour.
Or the plastic quick disconnects failed at some point and gas got spilled on the tranny. Once that happens the ugly stain is permanent. :( DAMHIK.
chibbert
Donating Member #: 202
Post by chibbert »
I'm with Boxer on this one. Depending on what oil was used, it's likely to turn dark quickly. No reason to jump to conclusions that the previous owner misled you.
2004 R1150RS
ekyang
Post by ekyang »
Yeah - my fuel quick disconnects came apart 10 miles from home - hence the discoloration. Suck!
Dr. Strangelove
Post by Dr. Strangelove »
I'm going to respectfully disagree on the oil color. At least in my case, the oil gets darker, yes, but not opaque black at all, more of a dark honey color that is transparent. Using Mobil 1 also, changing every 6k.
How thin was the oil when you drained it and did you do it hot?
And as others have attested, yes, that's the way the oil filter sits. It's safe, don't stress.
People tell you lots of things when you buy a bike, the only real way to tell the services were actually done is to run the VIN in a BMW dealer's computer and it will bring up what was performed. Get it printed out for your records. Best to do it before the sale
dahik
'09 Schwarze Blanche DuBois
ekyang
Post by ekyang »
Oil did seem pretty runny, not a thick viscous flow when fresh. And I only fired up the engine for 30 seconds before draining. Didn't run it around the block or anything.
Dr. Strangelove
If it was runny when cold, imagine what it was like when hot.
How many miles total on the bike when you bought it?
Was it serviced at a BMW dealer? If so, you can call BMWNA, 800 number, give them the VIN and they will help you determine what was done when, or not done.
I learned this lesson the hard way. When I bought my 12, after taking meticulous care of my 1150, Stella!, for 100k miles, I specifically asked if the 12k service was done, Oh, yes was the answer. I let it go at that. She had 14k on her. At 19 k I changed the oil and I have never seen such dark or thin oil. I went to the dealer and ran the VIN and there was no record of the 12k service ever being done. It would have only been done there. So the oil was probably 13k old, the 6k service was done.
It sounds like your situation. What I took away, other than trust, but verify, was that these engines are so robust that a missed oil change and running exhausted oil stresses out a new owner more than it does the bike. You caught it and took care of it. IN my case the final drive oil was as dark as the engine oil and the tranny's wasn't far behind. 10k of my miles and service on her now and she's pretty fine
Aside: You prob also want to change out the air filter as that was likely neglected. Easiest if the tank comes off for that and Beemer Boneyard is your friend for filters. If over 24k, you should change the alt belt, if never changed, you're risking dry rot.
With each bit of work you'll feel the difference. Learn how to do the valves and throttle bodies--a manometer is fine==all that stuff is easy and a zen experience :D
The Clymer's manual is a good shop manual.
Make sure the tie wraps on wire bundles in the front of the tank are not pinching and causing bad flexing of the wires.
When you've done all that you'll have the credentials to opine in tire and oil and windscreen threads. :)
The 1150s are great bikes and have lots of personality. They respond very well to the home mechanic, and this section of this site is filled with people to help. And this section has people who actually ride and for the most part have long experience with the 1150.
ekyang
Post by ekyang »
Thanks John - the bike only had 8300 miles on the odo when I bought it 4 weeks ago. Amazing that it was that old and it the prior owners didn't really ride it. My Haynes manual came in last week and I've already done the oil and filter, transmission fluid and final drive fluids. Am waiting for spark plugs to come in from Beemerboneyard as well as my replacement fuel quick disconnects (mine failed mid-ride about 10 miles from home on my way to a Carolina BMW Motorcycle Owners Association breakfast no less). Air filter looked ok but I blew it out with my air gun from my air compressor. Will also take a look at the belts now that I know what it entails.
Thanks for the advice on the pinched cables I'll be sure to cut those and replace with less pinching zip ties.
I have noticed that the protective sleeve for the cables are disintegrating. What do you guys use to replace the protective sleeve? I'm assuming you're not just using black electrical tape?
Boxer
Post by Boxer »
Running it for just 30 seconds was not enough to open the oil cooler thermostats, thereby storing some of the old oil in the coolers...about half a quart. IF you are going to run it to get the oil hot, for a more thorough oil change, you need to run it for at least 15 to 20 minutes for the oil to heat up properly. That half quart of old oil is now mixed with your new oil.
Make sure you take a picture of that sight glass after 200 miles for us.
Dr. Strangelove
What he ^ said
To expand any old thin dirty oil will sully your new oil. Some leave it drain overnight after a good "spirited" ride.
Leaning the bike to the right, don't drop it, will get out even more.
ekyang
Post by ekyang »
Boxer wrote:Running it for just 30 seconds was not enough to open the oil cooler thermostats, thereby storing some of the old oil in the coolers...about half a quart. IF you are going to run it to get the oil hot, for a more thorough oil change, you need to run it for at least 15 to 20 minutes for the oil to heat up properly. That half quart of old oil is now mixed with your new oil.
Very timely! I've actually been waiting for my new oil filters to come in - and I haven't filled my engine yet with fresh oil. I'll use some cheap auto oil I've got leftover, put that in, run it to get it nice and hot and then do a drain and replace with my Mobil 1 and new oil filter. And will take photos at different increments to see at what point does it start to go black in the sight glass.
ekyang
Post by ekyang »
And to be sure I'll let it drain completely overnight after the spirited ride. Had no idea that there's about 1/2 a quart of leftover oil in there as a result of the cooler thermostats not kicking in until a preset temperature is hit. I just have to be careful when I do the oil drainage post ride to not burn myself on the hot oil.
