Small air pump
Posted: Thu Aug 29, 2013 5:06 am
by MIKE46
Since taking delivery of my R1200R Classic I find that, with the bike having spoked wheels and inner tubes, I am having to check and adjust the tyre pressures before each ride whereas with my previous R1200R I only had to do it every month. I would like to find a small air pump to carry with me for use on longer trips. Has any one any recommendations?
Re: Small air pump
Posted: Thu Aug 29, 2013 5:58 am
by Catchina
I got a small pump from here
http://motopumps.com/
Re: Small air pump
Posted: Thu Aug 29, 2013 8:51 am
by jkhomes
The one I carry under my seat is made by Slime. I took it out of the carrying case so that it fits better. It comes with several plug types, and the one I left with the bike is the SAE plug that is the same as the pigtail I have on the battery for the charger.
Re: Small air pump
Posted: Thu Aug 29, 2013 12:13 pm
by Lost Rider
Like John said, a Slime pump fits under the seat, I carry mine in a ziplock bag with a SAE plug I replaced the original cigarette lighter plug with. For $10 it's proven to be very useful, mine's the Slime Top Up model.
I'm curious, why the need to check the air pressures daily with a tube vs tubeless, there's either a leak or there's not. Adjusting pressures regularly would seem to suggest you have a leak and should replace the tube. Both wheels?
Re: Small air pump
Posted: Thu Aug 29, 2013 2:39 pm
by AncientMariner
Aerostitch makes a great small pump for $40.00
I'm with Joe, tubes shouldn't be leaking. Easy to check, make sure the valves are screwed in all the way. Else you need a large tub of water...
Bruce
Re: Small air pump
Posted: Thu Aug 29, 2013 2:40 pm
by David R
I have this one and used it a few times. Good quality. Comes with the plug that fits your bike.
David
HI Catchina. Heading for maine today.
Re: Small air pump
Posted: Thu Aug 29, 2013 9:38 pm
Ditto on Joe's comment. My WAG why you have to "adjust" the pressure before every ride is you're losing air when you check it.. not an uncommon problem. Using a tire-pressure-monitoring-system (TPMS) helps avoid that. There was a discussion about them not too long ago here.
