Synthetic Oil or...
Posted: Wed Aug 31, 2005 9:19 am
by Blitz
Just wanted to get an idea how many of you are using a full synthetic oil and how often you do the oil changes as a result. Thanks.
Re: Synthetic Oil or...
Posted: Wed Aug 31, 2005 10:05 am
by jm1515
Blitz wrote:Just wanted to get an idea how many of you are using a full synthetic oil and how often you do the oil changes as a result. Thanks.
FWIW, I will be going to Mobil1 at ~10k...another 4000miles.
I will then do a 5000mi oil change interval....now it's 4000mi w/ Castol dino.
Posted: Wed Aug 31, 2005 10:07 am
by fnfalman
I stick with dino bones. If the bike were to warrant the use of synthetic oil then BMW engineers would have put it in the bike.
And I also stick with the scheduled maintenance laid out in the manual. I figure that those German engineers may just know something about the bikes that they design and make as well.
Posted: Wed Aug 31, 2005 10:22 am
by Badger
Been using Mobil 1 since the 12,000 mile service.....engine runs smooth and clean......keeps getting better and better......virtually no oil burned...
Posted: Wed Aug 31, 2005 11:18 am
by SLEDGE
MY bike has 26xxx miles.I use Valvoline full symthetic.20W50 change every 3mo. or 3,000M.
Posted: Wed Aug 31, 2005 1:39 pm
by yjleesvrr
I switched over to BMW synthetic at 12k miles on the odo. I change my oil every 3k miles. I now have close to 33k miles on the odo and the boxer engine is happy as a clam. No oil usage and runs smoothly as ever.
Posted: Wed Aug 31, 2005 2:06 pm
by FGanger
Not that I completely understand the difference, I use Mobil 1. :? It is supposed to be a “true synthetic” oil. I waited until my machine stopped using oil before I made the change.
Frank
Posted: Wed Aug 31, 2005 4:38 pm
by DJ Downunder
I started using a Mobil 1 type oil fully synthetic (Shell's equivelent 5-50w) after only 1000klms...now at 40,000 I've just started using a semi synthetic.(Castrol magnitec 10-40w)..no problems here.
Posted: Thu Sep 01, 2005 9:50 am
by tor1150r
Just had the 20k (12k miles) service done 2 days ago. I asked BMW about using synth. They are still recommending dino 20W50. They said the synth oil is not quite as viscous, and may result in some minor oil leaks/drops, although I have not read about this ever happening on this board.
I stick with the maint. schedule and use the recommended fluids, etc. I change the oil/filter every 5k kms (3k miles). The R rides fantastic and has been running even better now that it's nicely broken in.
So far the dino oil has been fine. I top up a little (100 ml maybe) after long rides (1000 kms or more) and check the oil after each outing. Burning next to nothing, if any oil.
Synthetics...
Posted: Thu Sep 01, 2005 10:41 am
by dallara
Synthetics all the way around here... and all Amsoil.
20W/50 in the engine.
75W/140 in the gearbox.
75W/90 in the final drive.
Change interval on the engine oil - 3,000 to 4,000 miles.
Change interval on the gearbox and final drive - 6,000 to 8,000 miles. (every other engine oil change).
Why? Because oil is cheap insurance, changing it often can't hurt, and it makes me feel better... :lol: :lol: :lol:
Cheers!
Dallara
Posted: Thu Sep 01, 2005 11:19 am
by Deans BMW
Engine 15/50 Mobil 1 synth
Tranny BMW 75/140 Synth
Rear Drive Mobil 1 75/90 Synth
R1150R switched at 6,000 miles
R1200ST switched at 4,700 miles
Neither bike uses oil at all.
Posted: Thu Sep 01, 2005 11:58 pm
by bmwdave52
Dallara said it all for me. :smt041
