Replacing main seal - need BMW tools
Posted: Mon Aug 11, 2014 6:12 pm
by UT R1150R
Edited to add some part number information I found on http://www.vintage-register.co.uk/post_ ... _hire.html
Hello everyone!
I haven't been on in I don't know how long but I'm still riding my 2004 R1150R and am still loving it. Recently I hit 50,000 miles and the clutch began slipping. I tore it all apart and learned that it was the transmission seals that had failed, making the clutch wet. I replaced each of the transmission seals (including that little foam thing that sits in the middle of the clutch actuation rod), the slave cylinder, clutch, and main seals.
Well, I installed the main seals using some tools I had in the garage and some homespun wisdom. I clearly didn't have enough wisdom and/or the right tools because after putting everything back together I went for a ride and the main seal leaked oil.
After feeling sorry for myself, I took the bike apart again (in 2.5 hours, mind you), and discovered that the inner seal was not completely pressed in.
Now, I'm ready to start over but want to use the official BMW tools to insert the seals. I have found one of them online but cannot find the others mentioned in the manual. I was hoping that someone here could give me some guidance or maybe be a super hero and let me borrow / buy their tools if they have them.
The tools mentioned in the manual are: (the one with the price is the one I've found online)
Part Number BMW Part Number Price
11 5 700 83300401585 Unknown
11 5 701 83300401586 Unknown
11 5 702 83300401587 Unknown
11 5 703 83300401588 Unknown
11 5 600 83300401564 (consists of 661 & 662) $92.77
11 5 661 N/A N/A
11 5 662 N/A N/A
00 5 500 Unknown Unknown
I appreciate very much any help you can provide!
Re: Replacing main seal - need BMW tools
Posted: Wed Aug 13, 2014 9:48 am
by Roy1150R
Max BMW lists these tools when searching by 11 digit part number.
83300401585 Drift set
83300401586 Mandrel
83300401587 Slip Sleeve
83300401588 Sleeve
Posted: Wed Aug 13, 2014 9:54 am
by UT R1150R
Thanks for the response, Roy.
I discovered yesterday that the price for all of those tools is approximately $656 :oops:
Thank goodness for a kind and generous service manager who let me take the tools home yesterday. I had the seals installed in about 5 minutes and returned the tools to him before the shop closed.
I couldn't test ride it though, since the grub screw is stripped out and as a result I could not bleed the clutch. Also, now the bike runs rough and idles fast so I'll try and figure that out tonight :-k
