I am trying to locate a replacement clip that attaches the headlight to the metal fairing. The bolt is a M6 bolt but no where is there in a parts list is there a m6 flat nut available. There are a multitude of M5 available but no where is the m6 listed.
Specifically I am talking about https://www.ascycles.com/2/MicroList?id ... 3%20Lights The bolt I am talking about is item 15.
Does anyone happen to know what the part # for this item is? I need to order it asap!
I have called A&S and my local shop and both are stumped. I was able to track down a m6 clip nut for the 1200GS http://parts.bmwmotorcycles.com/p/Brack ... 15831.html However I dont know if that will work as the tech said that some are different lengths.
Any help would be appreciated!
Headlight Attachment Nut Clip M6, Trying to Find!
Re: Headlight Attachment Nut Clip M6, Trying to Find!
To clarify, you are looking for the clip nuts attached to fore end of Rockster headlight/instrument "Front panel carrier" mounts? In fiche section 46_0825 the clip or flat nut is specified as M5 (item 5), as is the accompanying "flanged cap screw" (item 6).
FWIW, I prefer the standard fiche format used by Max BMW instead of whatever fubar system A&S uses to display fiche. Bob's BMW fiche rendition is even worse. RealOEM version is easy to use. Here's the panel carrier section in original fiche format, and RealOEM:
https://www.maxbmwmotorcycles.com/fiche ... d=07012015
http://www.realoem.com/bmw/enUS/showpar ... Id=46_0825
