Final drive oil amount
winkeldc
Post by winkeldc »
I know the most likely answer is to drain the old oil and refill with the 180ml but . . .
So last fall I lost the final drive bearing. Not thinking murphy would rear his head, I didn't think to replace the speedo sensor o-ring and washer(? not actually sure that what is referring to, but was on the part diagram so the dealer ordered) when replacing the fluid. Never even crossed my mind. I had the final drive removed because my insurance company required me to take the bike to the dealer to process a trip interruption claim, so when I refitted the drive, I used the speedo sensor as the fill point since that was already out. When I did the 600 mile fluid change recommended by the shop, I just didn't think to use the forward fill point because my last time through had just used the speedo sensor and I was in a hurry that day. Well, sprung a leak that looks like its coming from the speedo sensor. I have ordered the new parts, but I thought I read somewhere that 180ml takes the fluid level up to just below the drain bolt threads with the final drive back in position. Is this true? Could I replace the parts and then just fill the drive up to just below the drain plug? The more write ups I have read from the experienced members always measure and fill, so I am assuming that wherever I read about the level being about thread high must be mistaken or wishful thinking.
I am guessing that the answer is to drain and just refill with the correct amount, but I thought I'd ask while I am waiting for the parts to arrive.
mogu83
Re: Final drive oil amount
Post by mogu83 »
Your correct. Using the suggested amount is usually the best idea.
winkeldc
Post by winkeldc »
Thanks! I appreciate it. Makes me feel better that I am not throwing away good oil for no reason.
