Grip Warmer Failure
RonBomb
Grip Warmer Failure
Post by RonBomb »
The right grip warmer in my '02 R has stopped working. Anybody got advice on fixing it?
Thanks,
RonBomb
Motorcycling is like flying on the ground
Jax
Post by Jax »
Sounds like a wire has chaffed or broken in the right grip. Check the fuse to see if it's blown. Chances are, you're going to have to remove the throttle grip and check the wires.
Airman
Grip Heat
Post by Airman »
RonBomb,
Could have failed. My right grip was shorted out. I had ir replaced under warrenty, but it's not a difficult thing to change. I seem to recall the part was about $65. Cheaper from Chicago BMW no doubt.
A dealer will rack you for this in labor as they have to remove the tank. Do it yourself.
