not your normal Vibration issue. OVAD, TB's, nothing works..
Posted: Sun Jun 25, 2006 7:26 pm
Hello all. I just returned from a 4000 mile trip on my '04 Rockster that was very enjoyable, with one glaring exception that is driving me to the point of possibly selling my bike.
It all started during my 18k service, that I did myself ( along with my 6k , and 12k services, the last couple of years). My bike has been flawless for the three years that I've owned it, and I saw no reason to expect anything different for the next 3 years, and my previous services ( valves TB's fluids..etc) went great, with great results. I am very anal about being PRECISE on all the things that I do with the Rockster. My bike has always been a source of pride to me, and others look to me to help them service their BMW's and other makes. I'd call myself a good mechanic, with basic tools, and a good ability to understand how things work ( although my fat fingers seem to get in the way
After the 18k, ( and about 1 week before my big trip) the bike picked up a strong Buzzing vibration in the handlebars and footpegs from 3800 to 5000 RPM. Okay.........no big deal, right? TBs must be out. I go to check them and they are set like I normally would do , Mercury guages at idle and at 3000 rpm with no load.
I then thought that I must have not done the valves correctly............no problem.............I spend an hour to carefully redo the valves ( perfectly, mind you) and resync the TBs............
no change. still a very harsh vibration in the handlebars and footpegs.......very noticeable at 80mph cruising speed.
I'm starting to get worried at this point.....my trip is days away, and I don't have time to get to a dealer. what do I do?
I rigged up my mercury gauges to my tank bag with duct tape and wires, in an attempt to mimic a TwinMAX, whe I can check the TB's under load and during real use condidtions. SO.......down the road I went with my "contraption" working like a charm. ( boy.....di I get a few weird looks !!
I was able to watch my vaccuum change as the rpm's and load changed, and I attempted to "dial out" any imbalance in the 4-5k RMP range under load. I though I'd solved the problem, as there was some adjustments that I made to the TB's.
WRONG. still vibrates like a weed wacker................F*CK %*$(#@
I'm either going on a 4000 mile trip with a carpal tunnel syndrome machine, or I have to cancel.....................
I have to go on this trip!!!!!
One other point of notice..............I observed that my vaccuum changed significantly between one cylinder to the next, depending on load and speed.......ie at 3000rpm and light load, the right cylinder would show higher vaccum, but a 5000 rpm and medium load, the left would now show higher vaccum....................I thought my guages were screwed up, so I switched to the remaining two tubes of the carb stix, and got the same result!! difficult to balance TB's.............
I took off on a Saturday, doing approx 500 miles a day from WA to MN via Hwy 2, trying to ignore my "Buzz Bomb", with little sucess...........my hands went numb frequently, and I was denied some of the relaxation that a road trip like this will give me..............
I got to my Brother's place in Grand Forks ND ( he's an airhead guy), and quickly asked hime if I could use his feller guages and Carb Stix, to try and salvage the last half of the trip from the "BUZZ in the bars" . I found that my OVAD and TB's were spot on, even after 1500 miles of 80-90 mph cruising.
I changed the valves to slightly tight on intake and slightly loose on exhaust, hoping that ANY change would alter the harmonic being set up by the motor...............
you guessed it................no change.............vibes. Even my brother commented on the vibrating bi*ch, and said I should get an airhead, and i wouldn't have these types of problems.....................I ignored him
so...................I'll cut to the chase.............
6 total times to open the valve covers and re-adjust.........probably 20 attempts at TB sync.
I even chaged the oil back to BMW oil, thing that my oil was doind something to it.
I stopped into Big Sky BMW in Missoula Montana, to see if they could help. they were very busy, but offered to TB sync my bike. They said that it needed no adjustment, and they'd have to book me an appointment to realy check out the bike............I rode off to my home in WA.
so...........here I sit after a 4000 mile trip, with a buzzing BMW, that I want to sell, because I'm stumped.
I suppose that I should take it to the dealer, but I will be very upset if they say that they can't find anything wrong with it............ ( everything IS in spec!!!! )
why is my bike viberating? ( it is definitly engine speed related...not tires, or something else)
is the strange TB vacuum indicitive of an air leak?........I've tried to find one.........but can't
what did I do during the initial 18k service that might have done this?
my wifes Moto Guzzi is looking pretty good right now..........
hElp Rick
hElp Rick
