Biff's R wrote:
You and your friend can change all of the fluids(unless you have ABS brakes). Valve adjustment is pretty straight forward, and the twinmax carb balancer is easy to use.
Just remember to use a torque wrench when you retighten stuff.
Actually, you can also do the ABS fluid change and bleed. Just completed it this weekend on Mrs. North's R with iowabeester's advice and links:
http://users.rcn.com/dehager/service/ab ... dapter.pdf
http://users.rcn.com/dehager/service/service_abs3.pdf
You can make a filling adapter without the TOP adapter using a ProPex swivel faucet adapter (available at any plumbing or hardware store) and 5 minute epoxying it into a 3/8" opening funnel
Here's a link to the ProPex site that shows the fitting.
http://www.pexsupply.com/categories.asp ... 3&brandid=
You want the piece that is the insert part with the rubber rounded washer on the other end. This seats nicely into the ABS reservoir filler, but requires a buddy to hold it in place as opposed to the TOP adapter that screws in.
Here's a pic of my finished filler funnelthingy:
For the brake pad blocks, I couldn't find oak as recommended in the service PDF, but discovered that 1/2" plywood quickly sands down to .43". I had the hardware store pre-cut them to the right size so that I didn't have to bring out my saw and fuss with it.
One last little thing I discovered: If you have a mity-vac, this works better than the turkey-baster to "carefully remove old fluid from the reservoirs" . . . less mess.
If you want to save $$ on the TB Balancer see the post from cyclerob near the top of the forum right now: Another good $2 TwinMax substitute.
For the tank removal to get at the fuel filter etc., this is a good pictorial with step-by-step instructions:
http://home.mindspring.com/~jabrooks/te ... emoval.htm
My only other 2 pennies worth, is read through all the service literature that you have and make sure you have all the tools, filters, crush washers, clamps, extra fuel-line quick disconnect (for when you break one of yours trying to muscle it apart--can you tell I learned this the hard way
), plugs, etc. prior to getting started. Then make sure that you have enough beer
