best way to power an autocomm?
My dealer is optimistic my bike will be in and I'll be on the road by the end of the month.
With that, the first thing I want to hook up is my GPS and autocomm system. I've got the GPS covered with other threads on this forum (thank you).
Anyone know the best way to hook up the autocomm system? Mine is pretty old, don't have the model # with me at the moment.
Check out my setup:
http://www.dualsportridersoflouisiana.c ... stcount=45
In the first photo, the red/black wire at the bottom of the photo is run to the tail light running light to allow the power to switch on/off with the ignition key. It does not upset the CANBUS.
Doug
Doug
MSF #127350 NAUI #36288
2011 RT
2011 RT
Doug , I put my Centech AP-1 fuse panel in the same place you put your Audiocom. Have you found that your Audiocom Was indeed getting wet under there? I have driven miine for about an hour and a half in drenching rain with no noticable problems. I imagine that the addition of my hugger should keep it even more dry. This may just be wishful thinking though. I DO like the idea of the use of Pelican products though.
I have had no problems with water up in the area of the autocom setup, however being a pilot and lawyer, I am always looking for the "Murphy" factor, therefore the use of the Pelican box!celticus wrote:Doug , I put my Centech AP-1 fuse panel in the same place you put your Audiocom. Have you found that your Audiocom Was indeed getting wet under there? I have driven miine for about an hour and a half in drenching rain with no noticable problems. I imagine that the addition of my hugger should keep it even more dry. This may just be wishful thinking though. I DO like the idea of the use of Pelican products though.
Doug
2011 RT
2011 RT
Don , I have my radar detector powered off of the running light in the headlight. I bought a device that has a diode in line with the power so the Can't Bus never detects the added drain. It neatly plugs right into the back of the running light so there are no wires to cut into. I wish I could remember the name of the product and will post it when I do .
- thenewcamus
Don,
I havent seen a diagram of the R12's fusebox, but here is a link to how I powered my GPS by piggybacking off a fuse on my R1150...
http://r1150r.org/board/viewtopic.php?t=9884
Josh
2004 Rockster Citrus Green
- thenewcamus
A couple of other thoughts.
You want the Autocomm positive line to be on a switched fuse (I.E. Instruments), otherwise it will be powered all the time unless you switch it off at the unit (which is most likely under your seat and a pain to get to everytime you want to use it)
Also, Autocomm recommends attaching the negative line directly to the battery negative pole to isolate noise from the alternator. This is how I have mine setup and I get Zero noise.
I have my GPS on an "always on fuse" and my Autocomm on a switched fuse, with both negatives run directly to the battery.
Josh
