The winter storage debate/advice
I usually store my bike at the dealer. Yes. It's warm, secure, away from the elements and the battery is tricked (I don't think they remove it). I give them enough $$ during the season. I'd prefer to keep the 300$ in my pocket this winter!
I've read other posts here and poked around on-line for storage tips & advice. It all makes sense (oil change, clean/wax, cover, stabilizer, etc).
The part that varies is about the battery. Some say to remove it, some don't. Some say disconnect, some don't.
1. I have an unheated, dark, dry gargage. Many of my buddys store it in their garage with a trickle charger - that's it. Can I not do the same? I have the BMW motorcycle charger. I live in Toronto. It gets cold but far above arctic temps.
2. Is it common practice to remove the plugs and spray a defogging oil into the cylenders?
I know this seems a little like the "my oil level keeps changing" thread (numerous posts) but there are many different opinions out there, and it's really only 4 months of no riding (Dec through March).
07 R12GS - Granite
04 R1150R - Black (sold)
Member #468
Member #468
- geothepencil
Do you have salt vapor to consider coming off cars in the garage ? Rust and corrosion can be a factor in keeping it in the garage sometimes. With fuel injected bikes, I would just throw the charger on every two weeks and turn the tires at that time as well. I would rather see you siphon the gas out and refill in March than use a stabilizer if the gas is a concern to you. Not much else to do except wait for better weather. Several months isn't very long as you say. Don't short run the engine. A few short trips during the winter to full engine heat always make me feel better about it if that is possible for you.
geo
geo
I have the same situation as you. I put the bike away after filling the tank adding the correct of Seafoam, wash and wax, and tr4ickle gharge once a month. In the spring I change the oil, rear diff engine, bleed the brakes and I'm good to go. Been doing this for years on many different bikes and so far no problem. Normally I have done an oil change in Sept or Oct so it is fairly clean before winter; otherwise I might put clean oil before winter.
Michael
MG 78 LeMans
78 R100S
MG 78 LeMans
78 R100S
The garage is a single-car garage. My car stays outside all year. So the bike has exclusive use of it.
We have days during the winter that are suitable for a ride. Even if a dry sunny day looks great, the roads are caked with salt. I'll leave it there all winter.
Thanks!
Thanks!
07 R12GS - Granite
Member #468
Member #468
- iowabeakster
The advice above is the same as my own, except I change fluids before storage. Once I change the oil, the bike does not get started.
I also prefer not to ride on those rare nice days because of the salt. In the spring the motor oil is as fresh as if it were sitting in a bottle on the shelf, except that it is already in the bike.
tor1150r
I have another solution, being that you hail from Ontario. Take it to bed with you......I don't know if you are married and your wife would object.
A few years back, one of the posters on this board showed how it's done. I've been looking for that post but haven't been able to lay my hands on it yet...
- dragonmojo
Winter storage
If you have a liquid cooled bike................towerworker wrote:tor1150r--
One thing to make sure you do prior to storing the bike away for the winter-----don't know why no one has already mentioned it.......be certain to change the antifreeze in the radiators. It's been my experience that the factory stuff is only good for two years or so.
Martyn Hillier, Cheltenham, UK.
1979 R100RT, 2013 R1200RT, 2014 R1200R & 2016 R1200RT Iconic.
Boxermania.....I recall seeing a picture of some guy actually standing his bike up in an elevator to take it to his apartment. It was a BMW.
My wife wouldn't mind. She draws the limit when it comes to lifting it though!
Changed anti-freeze on the last service. Will top it up before laying it away.
Thx!
Thx!
07 R12GS - Granite
Member #468
Member #468
I'm in Ontario too, I store it in my garage with the trickle charger (I took the battary out one year...too much work! Otherwise, I do the usual - clean it, change oil, full tank, stabilizer, cover it on its center stand...that's it.
Our winters aren't too harsh anymore, and I powerwash my cars when they get salty.
Rui
'03 R1150R silver w/abs,black motor,bags,backrest,givi
'00 CBR929RR
'08 Road King Classic
'00 CBR929RR
- iowabeakster
I think the prodcedure was:boxermania wrote:tor1150r
1. flowers
2. dinner at a fancy restaurant
3. long-island iced tea
Gary C
A very timely subject for a newbie preparing to put his joy away for the winter. A specific question regarding the Odyssey PC-680 battery, I have decided not to remove the battery and will pull the fuse for the clock to reduce the drain. Is that good enough? and can someone recommend a charger et al for this battery?
Perhaps in the future those of us in Ontario will enjoy that California weather
Gary
Gary
I would recommend getting the BMW charger that plugs into your accessory port to keep a full charge on the battery.
You have a good battery and it would be a shame to have it die on you over the winter while it was not in use.
It is not excactly cheap, but well worth keeping a battery in good working order.
Buckster '03R
#543
#543
Gary C
...some R-humour. Sometimes you just have to roll with itcruiser wrote:tor1150r wrote: Changed anti-freeze on the last service. Will top it up before laying it away.
Thx!![]()
...I hesitate to post this but, what anti-freeze?? I thought the R1150R was oil/air cooled only. Mine is anyway...
07 R12GS - Granite
Member #468
Member #468
