Has anyone tried Tomahawk Tires?
Has anyone here tried Tomahawk Tires? http://www.cycletires.com/index2.html
I am just curious. I am out of synch by 50% on my tires, and want to get back to balance(front and rear wearing out together.
Jeff (lifer #289)
'17 F800GSA
'17 F800GSA
Never heard of them, but after discovering on the website their tires are re-treads, I say no way.
http://www.cycletires.com/faqs.htm
Veritas vos Liberabit
retreads
Have you noticed that there are , for the most part, zero sources for retread car tires nowdays? I used to work in a tire plant and it is noteworthy that the green unvulcanized rubber parts are cured together when the tire is assembled along with cements to facilitate the process. The carcass of course has a wear factor as well. I hope this thread dies much more quickly than a typical oil thread as it is a deadly subject in my opinion!
They are popular on sportier bikes. They are colored throughout, so they don't turn black. They are not specifically retreads in the sense that a new slab is stuck onto an old tire. I've known people who have used them for sport riding, and they were surprised that they worked pretty well considering their price. Not on par with say, a Pilot Power, but certainly better than some cheng Shin crap.
Mostly made for the poser factor. If they were deadly, they wouldn't have lasted this long(I've seen them out for 3 or 4 yrs now)
Jimbob
Monterey by the Bay
Monterey by the Bay
allanj255
Would not mind a pair of these on my R
[img][img]http://i243.photobucket.com/albums/ff26 ... /tyres.jpg[/img][/img]
Allan
Well, here's the thing. I looked into them a few years back. Considered using them on my track bike ($150 for a set of tires every 2-4 days is a lot better than $275 a pop). They are not "retreads" as in a new rubber layer glued to the carcus. The tires (Pirelli, Dunlop, Michelin...) are completely stripped and then new rubber is vulcanized on, just like when the tires are made. The technology they use comes from airplane tire remanufacturing. Tomahawk sponsors several racers that have had respectable results. Sport Rider did a test on them a while back (yeah they ended up in last place). So, although they didn't perform as well as the non-remanufactured tire brands, they also didn't blow up or fall apart...
Take a read at some of this stuff: http://www.cycletires.com/news.htm.
So, it's not all doom and gloom...
I bought a Tomahawk for my rear tire, after A nail put an end to my three day old Pilot Road. Reason I bought it was because i Purchased it and had it mounted for 80 bucks. Found out a cpl of weeks later that they are retreads. That being said, I put close to 8000 miles on the the tire before i had to replace it. I am not a REAL aggressive driver, but it gripped fine in the turns and was a good riding tire at high speeds. Did go back to a pilot road when the Tomahawk was replaced though. If you need a cheap tire fast, go with the Tomahawk, If you are wanting to get a colored scheme tire, go with the Tomahawk. Otherwise, go with what you know to be a good tire for your riding needs. Just my two-cents..
Corey
Corey
I received an email from a lurker and am posting it with his permission.
Here it is :
I've had several sets of Tomahawks, most recently on a 1200 bandit (none on my r1150r - yet), as part of an experiment, and due to cost for commuting use.
They are not "retreads" but "remolds".
(good carcasses are prepped, get complete new outers molded on as if they were new - different rubber pre-preg format used, but really similar to new)
They are prepped and processed like new tires, only diff is the used carcass.
Carcasses are good quality/brand tires, inspected, no junk brands.
(I'm a B level, lots of commute, some track, 51 yrs old, ~300k? lifetime miles on mix of sport, sport tour, bandit, blackbird, r/rt's, gs's, zx6, etc.)
I change my own tires as well.
My dad and I've used their remolds on planes for years, (as do most commercial operations) and a/c duty is pretty severe.
Reasons why to buy:
1 - half cost of new (only if you buy the blems, nothing wrong, typically some mold smear on id markings.
2 - dry performance is pretty good, but just a teeny bit "slimy" compared to new technology. I use the entire tread.
3 - colored tires (yes, it's all the way thru)
4- they do excellent dirt tires btw.
Reasons not to buy:
1- cost advantage not worth it (compared to sale prices of newer tech new tires, BT014's, MEZ6's, etc.) unless you buy Tomahawk blems.
2- lousy (bad) wet performance - really obvious over wet tar stripes etc.
3- continuous ignoramus opinions being offered are pretty tiring.
4- you have to be selective and persistent when ordering to get carcass type you really want - ie BT014, MEZ4, whatever base you want. Tomahawk/Cycletires aren't really setup to let you pick based on carcass (would be smart if they did), tho' every set is labelled with carcass they;re based on.
5- colored tires have to be cleaned to stay looking colored.
6- a bit more difficult to mount cleanly (edge material more sensitive to tool abrasion). Really visible when removing the old ones.
7- ;they don't make a "multicompound" like on mez6 (hard center, soft edge) or other newer tires.
Here it is :
Reasons why to buy:
Reasons not to buy:
Jeff (lifer #289)
'17 F800GSA
'17 F800GSA
