Idle Speed Adjustment - Is it Simple DIY taks?
civicblade
Post by civicblade »
My R1100r idles at ~1400rpm when warmed up.
I'm thinking of adjusting it down to the recommended 1000+150rpm range.
Do I have to adjust the left and right brass screw on th throttle pulley? Anyone with reference on how to adjust the idle speeds?
Thanks alot.
taosports
Re: Idle Speed Adjustment - Is it Simple DIY taks?
Post by taosports »
Over on the Adventure Rider site is a great page of links.
http://advwisdom.hogranch.com/Wisdom/
Scroll down towards the bottom and download the pdf link, TBSD. It will explain how to lower your idle. What you'll discover is that you really need a TwinMax or a home made manometer to do it correctly so that both throttle bodies stay in sync.
civicblade
Hi Taosports,
I've download the pdf file and it is great.
Sourcing for a twinmax now.
taosports wrote:Over on the Adventure Rider site is a great page of links.
philbytx
Post by philbytx »
Forget the TwinMax, complicated French contraption that it is...
Get yourself a Morgan Carbtune. No batteries to worry about and brain dead to use....
Phil C.
2003 R1150RT "DaRTh"
2000 R1100R "LeRoy
civicblade
I've made myself a balancer gauge by putting 2 glycerin filled dial style vacuum gauge side by side.
